POV-Ray : Newsgroups : povray.general : Does declaring an object reduce the rendering time? Server Time
24 Feb 2026 15:31:55 EST (-0500)
  Does declaring an object reduce the rendering time? (Message 1 to 7 of 7)
Subject: Does declaring an object reduce the rendering time?
Date: 3 May 2020 11:40:00
Message: <web.5eaee4abf2f979bdecc0fada0@news.povray.org>
Consider
union{
    sphere{<0,0,0>,1}
    sphere{<1,0,0>,1}
    sphere{<2,0,0>,1}
.... 10,000th sphere
texture{}
Is the rendering faster if we write it as
#declare S=sphere{<0,0,0>,1}
union{
    object{S translate<0,0,0>}
    object{S translate<1,0,0>}
    object{S translate<2,0,0>}
.... 10,000th object
texture{}
Note that the question is not about applying texture and normals, as they are
applied after the union.
I understand that the latter case consumes less memory, but the key problem is
the rendering time.
To my understanding, the time-consuming process is when POVRAY applies the
light. Otherwise, placing the object is the rapid step.
Subject: Re: Does declaring an object reduce the rendering time?
Date: 3 May 2020 12:06:15
Message: <5eaeebf7$1@news.povray.org>
Le 2020-05-03 à 11:35, Kima a écrit :
> Consider
> union{
>      sphere{<0,0,0>,1}
>      sphere{<1,0,0>,1}
>      sphere{<2,0,0>,1}
> texture{}
> union{
> texture{}
Not in your example.
> the rendering time.
Both cases will use about the same amount of memory and render in
exactly the same time. The second case will use a little bit more memory
to store the definition of the object used. That's the case for almost
every procedural primitives.
The only advantage here is the ability to change the object used by
changing a single line of code.
If, instead of spheres, you used some meshes, then, there would have
been a huge reduction on memory use.
In this case, the first form would need to store each individual meshes
while the second would instantiate a single mesh.
When using meshes, the reduction in memory use can prevent paging that
can dramatically bog down the rendering. It may even mean the difference
between been able to render at all and crashing.
Date: 3 May 2020 12:15:00
Message: <web.5eaeed5cc7817eb1fb0b41570@news.povray.org>
Check out this thread where we measure the elapsed time.
http://news.povray.org/povray.general/message/%3Cweb.59da2fc231ae2f125cafe28e0%40news.povray.org%3E/#%3Cweb.59da2fc231a
That's parsing time in the scene file.
You'll get the render time in the render statistics after the render completes.
Date: 3 May 2020 13:25:01
Message: <web.5eaefe62c7817eb1ecc0fada0@news.povray.org>
I'm very much interested in meshes. Does declaring the mesh affect the rendering
time?
I have 32/64 cores and 128GB memory. My CPU usage always reaches 100% but I
hardly see any memory consumption. This is the reason that my only concern is
the CPU usage.
Date: 3 May 2020 13:30:00
Message: <web.5eaefeedc7817eb1ecc0fada0@news.povray.org>
1a
The code is quite handy. In fact, I tried to run some benchmarks, but for the
sphere example, the difference is trivial to make any conclusion. And I was
afraid other factors may come to consideration if blindly test complex systems.
Thus, I asked my question from the theoretical perspective to understand the
fundamental concept.
Date: 4 May 2020 02:35:00
Message: <web.5eafb768c7817eb16adeaecb0@news.povray.org>
"Kima" <nomail@nomail> wrote:
> Consider
> union{
>     sphere{<0,0,0>,1}
>     sphere{<1,0,0>,1}
>     sphere{<2,0,0>,1}
> texture{}
> union{
> texture{}
> the rendering time.
I'm glad an initial declaration is indeed what we chose for Blender exporter, so
that Blender user object instances are kept as POV instances with only a matrix
transform. It made a huge difference when we did that change, though I'm sure
it's the place where subtle changes are to be optimized to hunt for even more
potential improvement.
Date: 4 May 2020 17:53:37
Message: <5eb08ee1$1@news.povray.org>
> time?
> the CPU usage.
POV-Ray is pretty efficient in it's memory use because it use procedural
primitives.
What use the most memory per object are single use mesh, image_map, the
images used as data source for height_field.
Next, using thousands, or even millions of objects.
Obviously, radiosity and photons scene need some extra memory.
You also need more memory if you want to render a larger image.
Using many instances of declared meshes will save memory as the mesh
reside in memory only once, but have no effect on the CPU usage and
render speed. If you are short on memory, not your case, that can have a
huge impact by preventing the use of virtual memory. If that happens,
you'll notice a marked decrease in CPU use.
Do a small test :
Have an include file defining a mesh WITHOUT using #declare.
In a loop, #include "Meshfile.inc" about 1000 times with some translation.
Take note of the memory use, parse time and render time.
Next, use
#declare MeshName = #include"Meshfile.inc"
then use it as many times.
Take note of the memory use, parse time and render time and compare.
Both should have the same, or almost same, render time.
Parse time should differ quite a bit.
Memory use should be very different.
