POV-Ray : Newsgroups : povray.general : no_image ignored in nested (difference > union > object) CSG member Server Time
25 Apr 2024 04:54:07 EDT (-0400)
  no_image ignored in nested (difference > union > object) CSG member (Message 11 to 18 of 18)
Subject: Re: no_image ignored in nested (difference > union > object)CSGmember
Date: 27 Mar 2020 09:58:52
Message: <5e7e069c$1@news.povray.org>
On 3/27/20 8:26 AM, Jim Holsenback wrote:
> On 3/25/20 1:11 PM, William F Pokorny wrote:
>> On 3/25/20 8:05 AM, William F Pokorny wrote:
>>> On 3/25/20 5:52 AM, Jim Holsenback wrote:
>>> Anyway, I've promised to do some other stuff first thing this
>>> morning. I'll come back to this thread later.
> Thanks Bill and Alain for the input...
> When you get a moment please review:
> http://wiki.povray.org/content?title=Special:RecentChanges&hidebots=0
http://wiki.povray.org/content/Reference:Object_Modifiers
Where we start with:
"Some conditions can produce unexpected results."
is there a way to make it a note? "Note..."
I don't know looking at the next sentence / list again...
"When applied to CSG components these modifiers work as expected: All
Transforms, inverse, bounded_by, clipped_by, cutaway_textures,
Hierarchy, and sturm."
What do you think about striking that sentence and only listing the next
items that mostly don't get passed through CSG - except where we have
unions not using split_unions off? I was trying to list things where I
thought people might wonder whether they make it through CSG, but maybe
it's just more confusing to do this?
I mean, I didn't list textures{} interior_texture{}, etc mostly because
I think folks know or quickly learn how those work in CSG. They get
attached to surfaces and do propagate through CSG except to the extent
those surfaces are seen in the resultant CSG (and cutaway_textures use).
Maybe your first take on a simpler statement with a list for what
doesn't always make it through CSG is more understandable?
We list "Hierarchy" and it doesn't get highlighted with a link perhaps
due the upper case H ?
Perhaps reword the sentence:
"Setting split_union off provides the exception with unions and their
accepting unions."
as
"CSG unions pass all modifiers listed above unless split_union off has
been set in which case the later list is ignored as with difference,
intersection and merge."
Could we start a new paragraph before:
"Interiors get attached to the objects where interiors are defined."
Starting that paragraph with:
"While not technically object modifiers, object interior blocks and
finish subsurface blocks see similar CSG propagation complications.
Interiors get attached"
Where we have:
"In the case of subsurface,"
Perhaps change that to:
"Further, in the case of subsurface, ..."
Suppose:
"See also: All Transforms translate, rotate and scale"
technically includes too: matrix and transform{}.
Thanks for working on this.
Bill P.
Date: 27 Mar 2020 16:36:13
Message: <5e7e63bd@news.povray.org>
you are correct... in this case less is more.
Date: 27 Mar 2020 23:48:22
Message: <5e7ec906$1@news.povray.org>
Yes. I think that latest looks good.
My head keeps coming up with more questions about what might and might
not work. But to test and enumerate all the fringe cases - ugh. And the
detail would only confuse.
Thanks again.
Bill P.
Date: 28 Mar 2020 10:00:00
Message: <web.5e7f57a1a6ce555cfb0b41570@news.povray.org>
Just asking out of curiosity - is there any way to flowchart most of this?
I often have a hard time deciphering the docs - because that's the nature of
documentation and language in general - but when there's a diagram or rendered
code example, to support the text, then it's usually much better.
Perhaps there's some debugging lines that can be inserted into a copy of the
source that will spit out how the stack of CSG onion layers gets "flattened".
Perhaps a simple POV-Ray scene that diagrammatically shows the "before" and
"after"  flattening attributes of CSG components just to illustrate the basic
concept graphically.
Date: 29 Mar 2020 10:41:11
Message: <5e80b387$1@news.povray.org>
Probably. "It's only a matter of code," as an old work friend would say. :-)
I'm with you on learning best from examples and diagrams. It's on my
list to dig more into the bounding / final internal representations
given I have a list of situations these days where bounding - or lack of
good bounding - is the largest component of a scenes render time.
I've wanted too, to be able to dump the internal representation after
parse and bounding, but no idea when I'll get something like that going.
At the moment focused on the pattern/function cleanup I was working on
late last year - but now in my cut down version of POV-Ray / povr.
Bill P.
Date: 29 Mar 2020 11:44:19
Message: <5e80c253$1@news.povray.org>
> I've got a little buzzer going off that somewhere in the last few years
> Christoph responded to someone hitting a particular hollow issue with it
> propagating or not as desired. I'll try and find that post.
On my initial search I couldn't find anything, but just now, while
creating a list of github issues and pull requests my cut down POV-Ray
addresses or fixes, I ran across:
object hierarchy changes hollow set flag #307
  https://github.com/POV-Ray/povray/issues/307
For reference. Looks like whether and how hollow works or not is change
v36 to v37 and complicated. Avoiding propagation through CSG still seems
to me the safest bet.
Bill P.
Date: 29 Mar 2020 12:05:24
Message: <5e80c744$1@news.povray.org>
And a few more for the record:
Port of FS183 - cutaway_textures broken with child unions
#207
https://github.com/POV-Ray/povray/issues/207
Port of FS115 - More cutaway_textures. Difference color inheritance
wrong. #196
https://github.com/POV-Ray/povray/issues/196
Unsure I agree with the conclusion of others in this one of it being a
bogus result... This sort of override happens all the time of object {},
if a user wants the cutaway_textures to work they should not create a
new overriding texture - or maybe I'm missing something.
Bill P.
Date: 4 Apr 2020 06:00:56
Message: <5e885ad8$1@news.povray.org>
  Yep, my head never shuts off on this stuff - a problem when it comes
to getting anything in particular done. I wondered this morning about
no_bump_scale and how it gets handled with normals...
The first paragraph of section 3.6.1.2.4 Scaling normals ends with the
sentence: "Think of this like the way no_shadow gets passed on to
objects contained in a CSG." which we know not to be generally true
today in v3.7 or v3.8 - and I expect never completely true.
However, seeing that comment got me thinking about Christoph's statement
about hollow treatments changing v36 to v37 with respect to which shape
in a CSG was used to propagate hollow statements to a CSG result
changing from the first to last - or maybe visa versa.
"Maybe," we could support some limited universal propagation of
no_shadow et al through csg by always propagating always from ONLY the
first object in the csg block? Is this what the pre - v37 coders intended?
In any case. If someone gets the time to dig. Maybe something limited
like a first shape only csg propagation could be supported in v38 which
would be of some help.
Bill P.
