POV-Ray : Newsgroups : povray.general : How is the arrangement of texture, pigment, and finish? Server Time
17 Aug 2025 01:49:21 EDT (-0400)
  How is the arrangement of texture, pigment, and finish? (Message 1 to 3 of 3)
Subject: How is the arrangement of texture, pigment, and finish?
Date: 1 Feb 2020 19:15:01
Message: <web.5e36136e5b8d0040ecc0fada0@news.povray.org>
It may seem a stupid question, but what is the difference between
object{ ...
    texture{
        pigment{ ... }
        finish{ ... }
and
object{ ...
    pigment{ ... }
    finish{ ... }
and
object{ ...
    pigment{ ...
        finish{ ... }
Subject: Re: How is the arrangement of texture, pigment, and finish?
Date: 1 Feb 2020 21:05:01
Message: <web.5e362e25a5419ea04eec112d0@news.povray.org>
> object{ ...
>     texture{
>         pigment{ ... }
>         finish{ ... }
> and
> object{ ...
>     pigment{ ... }
>     finish{ ... }
> and
> object{ ...
>     pigment{ ...
>         finish{ ... }
Functionally, I guess it will come down to syntax, and what can and cannot be
automatically "upgraded" from a lesser to a wider scope "thing".
Not sure about the last one - I had no idea you could put a finish statement
_inside_ a pigment statement.
material is the widest scope, acting as a kind of wrapper for texture, normal,
finish, interior
texture is a wrapper for pigment and color
I'm sure it may be covered ok in the docs, though those can be less clear at
times.  ;)
I'm sure someone else has a better, more accurate explanation.
The thing to keep in mind is that POV-Ray has grown sort of organically from an
independent seed - and it's still growing, so there are things that change, and
work _almost_ all of the time, and some things seem to work all of the time but
are really "broken" if you go digging deep enough...
So just experiment with what works and try to debug to the best of your ability.
Texture maps and material maps drive me nuts.
Date: 2 Feb 2020 10:02:14
Message: <5e36e476$1@news.povray.org>
> object{ ...
>      texture{
>          pigment{ ... }
>          finish{ ... }
Define the whole texture.
> and
> object{ ...
>      pigment{ ... }
>      finish{ ... }
Define the pigment with the default finish, then define a custom finish
that replace the default.
> and
> object{ ...
>      pigment{ ...
>          finish{ ... }
Start by defining a pigment with the default finish, but then define a
custom finish before finishing the pigment.
There is no functional difference between them, just different
flowcharts doing the same thing.
As it is possible, but not encouraged, to #declare an object from within
a pigment and use it elsewhere, there should be no problem with the
third and it should give the same result as the first two. It's just not
a recommended structure.
