POV-Ray : Newsgroups : povray.general : How to use Rounded Prism for objects with void? Server Time
22 Dec 2024 16:49:57 EST (-0500)
  How to use Rounded Prism for objects with void? (Message 1 to 3 of 3)
Subject: How to use Rounded Prism for objects with void?
Date: 28 Jan 2020 13:20:00
Message: <web.5e307b1e33de45afecc0fada0@news.povray.org>
The macro given at http://www.slimeland.com/misc/roundedprism.inc is very handy
for building a rounded prism. However, I cannot create any rounded prism if the
object has a void within like
https://www.povray.org/documentation/images/tutorial/subshape.png
How can I create a rounded prism for an object like
prism {
    linear_sweep
    cubic_spline
    0,  // sweep the following shape from here ...
    1,  // ... up through here
    18, // the number of points making up the shape ...
    <3,-5>, <3,5>, <-5,0>, <3, -5>, <3,5>, <-5,0>,//sub-shape #1
    <2,-4>, <2,4>, <-4,0>, <2,-4>, <2,4>, <-4,0>, //sub-shape #2
    <1,-3>, <1,3>, <-3,0>, <1, -3>, <1,3>, <-3,0> //sub-shape #3
    pigment { Green }
Subject: Re: How to use Rounded Prism for objects with void?
Date: 29 Jan 2020 12:50:00
Message: <web.5e31c4ee23de503bbe7517870@news.povray.org>
> prism {
>     linear_sweep
>     cubic_spline
>     pigment { Green }
The incredible Sam Benge provided his Rounded Linear Prism macros back in 2010.
You can find them in the POV-Ray Object Collection - in the Resources section of
Home, same place as these newsgroups.
Don't know if you have seen these and rejected them, but you don't mention them.
The example he gives is a P. I think that is what you mean by void.
If you search on rounded prism and wade through a few results you will get to
the posts. Sam called them the rlp macros.
They took only straight lines and circular arcs, but this turned out to be less
of a restriction than you might think, given that sharp corners, that is corners
from line segment to line line segment rather than line segment to circular arc,
could be rounded.
JimT
Date: 29 Jan 2020 19:10:00
Message: <web.5e321e1d23de503becc0fada0@news.povray.org>
> > prism {
> >     linear_sweep
> >     cubic_spline
> >     pigment { Green }
> could be rounded.
> JimT
Thanks very much. When you mentioned "P", I just recalled that I've already seen
it. Funny enough, I didn't need to search for it as I could find it on my
computer. So silly of me.
Anyhow, you saved me from re-inventing the wheel.
