POV-Ray : Newsgroups : povray.general : How to make film projector cone/spotlight Server Time
22 Mar 2026 03:35:19 EDT (-0400)
  How to make film projector cone/spotlight (Message 1 to 10 of 10)
Subject: How to make film projector cone/spotlight
Date: 17 Dec 2019 18:55:01
Message: <web.5df969e39d72d04361174e600@news.povray.org>
Hi, I'm trying to create a movie projector and have it project an image onto
onto other surfaces. I'd also like to have a cone shape volumetric effect for
the dust in the air near the projector. How would I go about this in POV Ray?
Subject: Re: How to make film projector cone/spotlight
Date: 18 Dec 2019 02:35:58
Message: <5df9d6de$1@news.povray.org>
Op 18/12/2019 om 00:50 schreef tmelram:
Just thinking aloud, I would suggest to try the following:
1) use a spot light
2) as an image, use a plane/box intersection with an appropriate
image_map, using some transparency
3) test how this projects upon a white screen (thin box or equivalent);
probably not good enough (see below)
4) for dust in the air, use an isotropic scattering media
I don't know how this would work out, especially the projection on the
screen. You might probably need to add/construct a lens with an
appropriate interior and especially ior.
Date: 18 Dec 2019 06:20:23
Message: <5dfa0b77$1@news.povray.org>
tmelram wrote on 18/12/2019 00:50:
Mmmm. Years ago I made a little test on this subject, you can find it on
p.b.s and adjust it following the suggestions of Thomas.
Hope it helps,
    Paolo
Date: 18 Dec 2019 06:54:32
Message: <5dfa1378$1@news.povray.org>
Op 18/12/2019 om 08:35 schreef Thomas de Groot:
>> image onto
>> effect for
>> POV Ray?
> 1) use a spot light
Something I forgot to mention: photons might be what you want to use too.
Date: 18 Dec 2019 13:40:01
Message: <web.5dfa715fe2b94cab8c662f470@news.povray.org>
hi,
found the changes in output when rendering the scene for different '#version's
very interesting, only '3.6' gives me the expected result.  (using
alpha.10064268)
regards, jr.
Date: 19 Dec 2019 11:36:35
Message: <5dfba713$1@news.povray.org>
Take a look at
<http://www.f-lohmueller.de/pov_tut/interior/interior_20e.htm>
Kurtz le pirate
Compagnie de la Banquise
Date: 21 Dec 2019 04:45:00
Message: <web.5dfde84ae2b94cab54809c2a0@news.povray.org>
Is this the sort of thing you want? If so I'll look out the code.
Incidentally the "photograph" is one of Thomas's entries to TC-RTC.
https://i.imgur.com/Oqmn1.jpg
Date: 21 Dec 2019 06:37:36
Message: <5dfe0400$1@news.povray.org>
Op 21/12/2019 om 10:41 schreef Stephen:
LOL!
[still one of my images I am most proud of]
Date: 21 Dec 2019 12:00:01
Message: <web.5dfe4f21e2b94cab54809c2a0@news.povray.org>
> LOL!
As you should be. :-D
Date: 8 Jan 2020 03:49:24
Message: <5e159794$1@news.povray.org>
jr wrote on 18/12/2019 19:35:
> hi,
> alpha.10064268)
> regards, jr.
Curious. It was an old scene, I will get a look.
Thank you,
    Paolo
