POV-Ray : Newsgroups : povray.general : SEVERE shadow problems with Blender POV renders?? Is anyone familiar with i= Server Time
29 Mar 2024 07:11:52 EDT (-0400)
  SEVERE shadow problems with Blender POV renders?? Is anyone familiar with i= (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: SEVERE shadow problems with Blender POV renders?? Is anyone familiar wi=
Date: 18 Nov 2019 17:20:00
Message: <web.5dd3180cf0a1c145c8bf72b50@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> "tmelram" <taj### [at] yahoocom> wrote:
> > Hi, I am using Blender to model and wanted to use POV ray to render my scenes.
> > But, I'm getting serious shadow issues. There seem to be triangles near wherever
> > there are shadows!
> > A picture of the problem:
> > https://i.imgur.com/z6Ftxv6.png
> > How can I remedy this??
> I guess it would be helpful to see the (generated) scene code.
> regards, jr.
Here's what happened when I  tried to use the code you posted:
https://i.imgur.com/vEm5hnZ.png
Date: 19 Nov 2019 07:30:01
Message: <web.5dd3dfbaf0a1c145feeb22ff0@news.povray.org>
hi,
scenes.
wherever
> > > > > there are shadows!
> > > > regards, jr.
> > > Sure, here you go:
> > not sure of the cause, but changing the light_source makes for a smooth shadow
> > line, ie I did:
> Thanks, it worked!. But, it seems to have flipped the direction of the light.
yes.  I left out the transform.
> It's either upside-down,backwards, or both. I chose a simple sphere with one
> light just to test. But for a more complex scene it might help to know what
> exactly did you change to make it so that there wouldn't be any triangles. What
> did you do?
nothing else.
as Mr and B Pokorny have mentioned, perhaps use a "real" sphere, or, if there's
a need for the mesh2, try using 'smooth triangles' (see documentation on 'mesh2'
object).
sorry to be of little help, I do not use Blender.
> Also I found this article:
> http://wiki.povray.org/content/Knowledgebase:The_Shadow_Line_Artifact
> What do you think of it and the solutions?
depending on the scene you're working on, I think playing with 'shadowless' in
the lights, and or with 'no_shadow' object modifier, is definitely worth trying.
regards, jr.
Subject: Re: SEVERE shadow problems with Blender POV renders?? Is anyone familiar with i=
Date: 19 Nov 2019 12:50:40
Message: <5dd42b70$1@news.povray.org>
> there are shadows!
This is a mesh sphere. The triangle are places where the triangles
composing the sphere are actually pointing away from the light but their
normals would demand that they be illuminated.
The usual solutions are :
Subdivide the mesh. (make the triangles smaller)
Use an area_light with the area_illumination feature. (make the
terminator more fuzzy)
Rotate the object or change the location of the light. (shift the
problem area out of view or shift the light so that it no longe cause
the problem)
None of those are perfect. All often still show those triangles, but
make them less visible or smaller. The last option listed can, in some
cases, hide the problem area, but probably won't work in this case.
Date: 19 Nov 2019 12:56:23
Message: <5dd42cc7$1@news.povray.org>
Le 2019-11-19 à 07:27, jr a écrit :
> hi,
wherever
>>>>>> there are shadows!
>>>>> regards, jr.
>>>> Sure, here you go:
>>> line, ie I did:
>> did you do?
> nothing else.
> object).
> regards, jr.
The model already use smooth_triangle.
Using shadowless will kill any highlight from that light. It will also
render the use of photons impossible as shadowless light NEVER shoot any
photon.
Using no_shadow may hide those artefacts by suppressing self shadowing,
but the object will no longer cast any shadow in the scene.
Date: 19 Nov 2019 12:59:39
Message: <5dd42d8b$1@news.povray.org>
>>> there are shadows!
> Well - those appear to be actual triangles.  Can you export from Blender with
> the msh2 object format, rather than mesh?
> Then you could use the smooth_triangles to get a better geometric surface.
http://wiki.povray.org/content/Documentation:Tutorial_Section_3.1#Polygon_Based_Shapes
IIRC, Blender already export it's meshes with smooth triangles UNLESS
instructed not to.
Solution : Subdivide the mesh. Wuill make the object use more memory.
Using an area_light with area_illumination can help make those less visible.
Date: 19 Nov 2019 17:35:01
Message: <web.5dd46d0af0a1c145c8bf72b50@news.povray.org>
> hi,
scenes.
wherever
> > > > > > there are shadows!
> > > > > regards, jr.
> > > > Sure, here you go:
> > > line, ie I did:
> > did you do?
> nothing else.
> object).
> regards, jr.
You left out the transform? Do you mind posting the code for that?
Date: 19 Nov 2019 18:35:01
Message: <web.5dd47be4f0a1c145feeb22ff0@news.povray.org>
hi,
yes, no "transformation matrix" (same code as shown before):
#if (0)
light_source {
    < 0,0,0 >
    color rgb<2, 2, 2>
    spotlight
    falloff 22.50
    radius 19.125000
    tightness 0
    point_at  <0, 0, -1>
    fade_distance 12.500000
    fade_power 2
    matrix <0.901870, 0.180445, -0.392519,  -0.417916, 0.594587, -0.686886,
0.109441, 0.783522, 0.611650,  0.000000, 18.516430, 14.742990>
#declare lampTarget1= vrotate(<-0,14.74,-18.52>,<0.6492,-0.1814,0.4105>);
#else
light_source {0 colour srgb 1 parallel}
regards, jr.
Subject: Re: SEVERE shadow problems with Blender POV renders?? Is anyonefamiliar with i=
Date: 20 Nov 2019 02:25:01
Message: <5dd4ea4d$1@news.povray.org>
Op 19/11/2019 om 18:50 schreef Alain Martel:
> the problem)
I agree. In my personal experience with mesh2 objects, subdivision is
the best way to go. It means heavy subdivision is some cases, especially
when dealing with smooth objects. Additionally, this can be alleviated
to some extend by applying a (micro) normal to the object, as this also
helps to hide the triangles.
Date: 20 Nov 2019 11:50:47
Message: <5dd56ee7$1@news.povray.org>
> there are shadows!
I don't use meshes often myself, but played with your scene a bit today
using the shipped shapes.inc HF_Sphere macro to learn. I had to
sub-divide to around 2500 points before the artifacts mostly gone and
10000 points before really clean. Renders without AA. Your original mesh
had 482 points.
FYI. The problem here is a general one and called variously out and
about as the "terminator shadow artifact" / "terminator artifact" /
"terminator issue" / "shadow artifacts" and so on. A few tools have
claimed fixes - which involve on the fly fudging of one sort or other
where I've peaked at them. Christoph (clipka) was working on / had in
mind some 'fix' for POV-Ray, but not sure where it stands implementation
wise.
The workarounds others have suggested are the ones I'm aware of for
POV-Ray.
Bill P.
Subject: Re: SEVERE shadow problems with Blender POV renders?? Isanyonefamiliar with i=
Date: 21 Nov 2019 15:11:44
Message: <5dd6ef80@news.povray.org>
>> their normals would demand that they be illuminated.
>> the problem)
Or use a noisy texture that can also help hide those triangles.
