POV-Ray : Newsgroups : povray.general : How to customize the output? Server Time
14 Jul 2025 14:26:29 EDT (-0400)
  How to customize the output? (Message 1 to 3 of 3)
Subject: How to customize the output?
Date: 9 Oct 2019 09:15:00
Message: <web.5d9ddd0fba522ca3ecc0fada0@news.povray.org>
Following a subtle suggestion at
http://news.povray.org/povray.general/thread/%3Cweb.5d9c84adcc983787ecc0fada0%40news.povray.org%3E/
I need to calculate the object width in the first run, and parse the output of
#debug stream to set the camera location in the main run.
I do this by a shell script in linux, but the output of povray command contains
lots of information (credit, rendering, etc).
How can I limit the output of the povray command to #debug stream?
Subject: Re: How to customize the output?
Date: 9 Oct 2019 09:25:01
Message: <web.5d9ddf6e495e39d5feeb22ff0@news.povray.org>
hi,
<http://wiki.povray.org/content/Reference:Text_Output_Options>
however, I'd be tempted to write the information needed to a text file, from the
scene (ie using '#write').  that way you you can reduce the need for "parsing"
(or, at least, make the task easier).
<http://wiki.povray.org/content/Reference:File_I/O_Directives>
regards, jr.
Date: 9 Oct 2019 18:04:11
Message: <5d9e595b$1@news.povray.org>
On 10/9/19 9:23 AM, jr wrote:
> hi,
> regards, jr.
I like jr's suggestion.
The way I do it is with parsing.  You can't really control the noise
around you, so make your noise noticeable.
i.e.
#debug concat("[myData] ObjectWidth ", str(ObjectWidth,0,3), "\n")
Then you know any line beginning with [myData] is one you care about for
this application and you can ignore everything else.
dik
Rendered 1024 of 2073600 pixels (0%)
