POV-Ray : Newsgroups : povray.general : Absorption vs thickness Server Time
17 Aug 2025 09:33:33 EDT (-0400)
  Absorption vs thickness (Message 1 to 6 of 6)
Subject: Absorption vs thickness
Date: 27 Sep 2019 09:15:00
Message: <web.5d8e0a843f3612417bf1a5370@news.povray.org>
maybe this is an ancient (and stupid?) question, but after online search I still
don't find anything useful.
In PovRay, two semitransparent boxes with very different thickness but with same
rgbt values have the same appearance. The absorption/transmission doesn't depend
on box thickness. The same even using "media { absorption rgb <.,.,.> }". This
is a sample code:
box {<-250,0,0><250,500,100>
    texture {pigment {rgbt <.6,0,0,0.5>}}
    interior {ior 1.5 media { absorption rgb 0.0001*<1,1,1> } }
    hollow on
    rotate <0,0,0> translate <-250,0,100>}
box {<-250,0,0><250,500,1000>
    hollow on
    rotate <0,0,0> translate <250,0,100>}
This is not physical. Is there a way to simulate the real thickness dependence
Thank you!
igmar
Subject: Re: Absorption vs thickness
Date: 27 Sep 2019 10:15:00
Message: <web.5d8e19305a27978d7bf1a5370@news.povray.org>
I was wrong: media {absorption .. } do exactly what required.
Sorry!
igmar
Date: 27 Sep 2019 11:35:46
Message: <5d8e2c52$1@news.povray.org>
> Sorry!
> igmar
Hi, You might find interior's fade_color, fade_distance and fade_power
of use too.
Bill P.
Date: 27 Sep 2019 11:58:20
Message: <5d8e319c$1@news.povray.org>
Le 2019-09-27 à 09:11, IGM a écrit :
> Hi,
> is a sample code:
>      hollow on
>      hollow on
> of absorption/transmission? (Beer–Lambert law)
> Thank you!
> igmar
What you want is to add an interior block to that object that define
light fading through that object :
interior{fade_colour Some_Colour fade_distance Distance fade_power 1001}
For realistic results, fade_power should be 1 or 1001.
fade_distance dictate the intensity of the fading, ow how fast the
fade_colour affect the colour of what is behind your object.
In that same interior block, you can also set an index of refraction, or
IOR, as well as the amount of spectral dispersion. Use real world IOR
and dispersion values.
interior{
  ior 1.33 // water. Default value is 1
  dispersion 1.01 // default to 1
  dispersion_samples 10 // optional, have a default value
Also, as you discovered, the interior block can also be used to fill an
object with some media.
Date: 27 Sep 2019 12:20:01
Message: <web.5d8e36625a27978de462584c0@news.povray.org>
Thank you both, Alain and William,
I didn't notice that fade_distance and fade_power were interior properties,
besides being light_source properties!
igmar
Date: 28 Sep 2019 14:22:02
Message: <5d8fa4ca$1@news.povray.org>
> igmar
It's important to note that it don't work the same way for light_source
and interior.
For the lights, it affect the intensity of the light only. The colour
never change.
In an interior block it affect how the material affect the light going
through and can change the colour.
