POV-Ray : Newsgroups : povray.general : How arrange a few text objects Server Time
17 Aug 2025 09:17:58 EDT (-0400)
  How arrange a few text objects (Message 1 to 4 of 4)
Subject: How arrange a few text objects
Date: 6 Sep 2019 15:35:00
Message: <web.5d72b3cc91779769ecc0fada0@news.povray.org>
When we have a few separate text objects as
#local t1=text{ ttf "font.ttf", "First", 1, 0 texture{ pigment{ rgb <1,1,1> }}
#local t2=text{ ttf "font.ttf", "Second", 1, 0 texture{ pigment{ rgb <1,1,1> }}
#local t3=text{ ttf "font.ttf", "Third", 1, 0 texture{ pigment{ rgb <1,1,1> }}
union {t1 t2 t3}
how can we place the object after each other on the x-axis to read the text as
"First Second Third"?
I mean how to find the end of each element to place the next one.
I tried to use max_extent, but was confused where to use it to get the last
location of the previous element.
Subject: Re: How arrange a few text objects
Date: 6 Sep 2019 19:30:00
Message: <web.5d72eacf85cf5efee87cbad00@news.povray.org>
> union {t1 t2 t3}
Don't use union.   All that does is treat them all as one compound object.
Use concat ("First", " ", "Second", " ", "Third")
I just put separate spaces in there to show you how to format the command, and
that it doesn't insert any for you.
So,
#local T = concat ("First", " ", "Second", " ", "Third");
object {T texture {pigment {rgb <1,1,1> } }
Date: 6 Sep 2019 19:50:00
Message: <web.5d72f06585cf5efeecc0fada0@news.povray.org>
> > union {t1 t2 t3}
> So,
I cannot combine the texts, as they are separate with different fonts.
Date: 6 Sep 2019 20:25:00
Message: <web.5d72f86e85cf5efee87cbad00@news.povray.org>
Ah.  Righto.
So if you use min_extent and max_extent, you can use those to align things.
http://wiki.povray.org/content/Knowledgebase:Language_Questions_and_Tips
So,
you have:
Try:
#declare spacing = 1.0;
#local t1x = max_extent (t1).x;
     translate x*(t1x+spacing)}
#local t2x = max_extent (t2).x;
translate x*(t2x+spacing)}
Not that by appending ".x" to max_extent, I'm selecting only the x component of
the <x, y, z> vector that the function returns.  That way I'm only translating
along x.
Then you can
union {
     object {t1}
     object {t2}
     object {t3}
