On 8/19/19 3:18 PM, Kima wrote:
> I can use bezier_spline set of points in lathe as
> lathe {
> bezier_spline
> 80
> <2.00, 1.00>, <1.00, 1.50>, <3.00, 3.50>, <2.00, 4.00>
> <2.00, 4.00>, <3.00, 4.50>, <1.00, 6.50>,<2.00, 7.00>
> pigment { color rgbt<0.4,0.2,1,.5>}
> finish { ambient 1 }
> but when I use the same set in prism as
> prism {
> bezier_spline
> 0,1,1,
> // 80
> I get an error, "Prism with Bezier splines must have four points per segment."
> Where did I do wrong?
Hi. Not sure how either works. In the first where you have '80' I think
it should be '8,'. In the second where you have '0,1,1,' I think
'0,1,8,' is what is needed. In the latter the parser is probably seeing
the 1 as the point count and saying you need at least 4 for a valid
segment.
Bill P.
> > lathe {
> > bezier_spline
> > 80
> > prism {
> > bezier_spline
> > 0,1,1,
> > // 80
> segment.
> Bill P.
Thanks, Bill. 80 in lathe was a typo, as I clipped a larger bezier_spline set
for readability here. My mistake was the third parameter of prism. Now
everything works perfectly. Thank you very much.
I tried the fixed prism, but that doesn't work for me. The lathe works fine, but
with the prism, I only see nothing. Thats my code:
#version 3.7; // 3.7
global_settings{assumed_gamma 1.0}
#default{ finish{ ambient 0.2 diffuse 0.9 }}
#default{pigment{rgb <0.800, 0.800, 0.800>}}
#include "textures.inc"
// camera ----------------------------------
#declare CamUp = < 0, 0, 1>;
#declare CamRight = <1.33, 0, 0>;
#declare CamRotation = <-35.264390534, 1.9538003485e-05, 45.0000026303>;
#declare CamPosition = <17.0710754395, -7.07106590271, 17.0710659027>;
location <0, 0, 0>
direction < 0, 1, 0>
up CamUp
right CamRight
rotate CamRotation
translate CamPosition
angle 57.82
// sun -------------------------------------
light_source { <17.0710754395, -7.07106590271, 17.0710659027> color rgb<0.5,
0.5, 0.5> }
// background ------------------------------
sky_sphere {
gradient z
color_map {
[ 0.00 color rgb<0.098, 0.667, 0.067> ]
[ 0.30 color rgb<0.098, 0.667, 0.067> ]
[ 0.50 color rgb<0.576, 0.000, 0.000> ]
[ 0.70 color rgb<0.200, 0.200, 0.396> ]
[ 1.00 color rgb<0.200, 0.200, 0.396> ]
scale 2
translate -1
rotate<-35.264390534, 1.9538003485e-05, 45.0000026303>
// objects in scene ------------------------
prism {
bezier_spline
0,.2,8,
lathe {
bezier_spline
8
Thanks in advance!
hi,
when I comment out bezier_spline, ie using default spline type, the prism shows.
otherwise POV-Ray complains about prism "not closed". hth.
regards, jr.
"jr" <cre### [at] gmailcom> wrote:
> hi,
> regards, jr.
OK, that's crazy :) With my POV-ray on Linux Mint 19 Cinnamon there a no errors,
also with the not outcommented bezier_spline. The only thing POV-Ray shows me,
is
that (with both, outcommented and not outcommented):
Ray->Shape Intersection
usbhub
hi,
using v3.8 and and v3.71 on Slackware Linux. not error, "Parse Warning" prism
not closed, ie not enough points. when using default linear spline, POV-Ray
closes the prism for you, not with other splines (afaik).
> is
strange.
regards ,jr.
Now it works! The solution is, that the direction of the tangents at the start
and end control point of joining curves must be identical.
(http://wiki.povray.org/content/HowTo:Use_Splines_and_Bezier_Curves)
With this example it works:
prism {
bezier_spline
0, 10, 16
<0, 1>, <.5, 1>, <1, .5>, <1, 0>
<1, 0>, <1, -.5>, <.5, -1>, <0, -1>
<0, -1>, <-.5, -1>, <-1, -.5>, <-1, 0>
<-1, 0>, <-1, .5>, <-.5, 1>, <0, 1>
But now is the question, how can I make edges in the spline?
Thank you very much jr!
I don't understand POV-Ray :)
This example works also, even there are edges:
prism {
bezier_spline
0, 10, 16
<0, 1>, <.5, 1>, <1, 1.5>, <1, 0>
<0, -1>, <-.5, -3>, <-1, -.5>, <-1, 0>
<-1, 0>, <-1, .5>, <-.5, 5>, <0, 1>
I don't know why it works now, but whatever.
usbhub
hi,
> This example works also, ...
> usbhub
keep going. some here, including self, find (strong) coffee an invaluable help.
note that the "finish {ambient 1}" also will give you grief (ie POV-Ray
warnings) when/if you upgrade to v3.8.
regards, jr.
Yes, if you're piecing together splines, then you need to do that to make them
smoothly continuous.
What do you mean "make edges"?
Do you want just a "linear" spline that doesn't "enclose a shape"?
