POV-Ray : Newsgroups : povray.general : Aiming a spaceship Server Time
14 Jul 2025 17:13:46 EDT (-0400)
  Aiming a spaceship (Message 1 to 2 of 2)
Subject: Aiming a spaceship
Date: 20 Mar 2019 21:30:01
Message: <web.5c92e8379a594812cd3d062c0@news.povray.org>
Finally got a routine to point my spaceships.  Each is built along the X axis,
in the positive X direction.  I've used a spline to define the spaceships
motion, but getting the ship to point into the direction it is going.
But here it is:
#macro aimAt(p_cur, p_new )
// given an object around origin pointing in the x direction,
// generate a rotation so it can go from p_cur to p_new
#local p_diff = p_new - p_cur; // where it's headed (vector normalized to
origin)
#local y_angle =  -  atan2d(p_diff.z,p_diff.x) ;
#local xy_diff = sqrt(p_diff.x*p_diff.x + p_diff.z*p_diff.z);
#local z_angle =  atan2d(p_diff.y,xy_diff) ;
// #if (p_diff.y < 1) #local z_angle = -z_angle; #end
rotate <0,0,z_angle>
rotate <0,y_angle,0>
#end // aim at
And an example of it's use (cccc is a variable based off of the clock):
object{ Freebooter(1) aimAt( moveSpline(cccc), moveSpline(cccc+.001) )
             translate moveSpline(cccc) - <-90,-100,-100>  no_shadow  }
Enjoy!
Tom A.
Subject: Re: Aiming a spaceship
Date: 1 Apr 2019 07:45:23
Message: <5ca1f9d3$1@news.povray.org>
Does your spaceship adhere to Newtonian physics? In which case your ship
will slide around a lot and not necessarily point in the direction you
are moving.
Mike
> But here it is:
> origin)
> #end // aim at
> Enjoy!
> Tom A.
