POV-Ray : Newsgroups : povray.general : Bezier spline approximations to circles Server Time
5 Mar 2026 02:21:22 EST (-0500)
  Bezier spline approximations to circles (Message 1 to 4 of 4)
Subject: Bezier spline approximations to circles
Date: 22 Jan 2019 10:25:00
Message: <web.5c47356c36095c6fbe7517870@news.povray.org>
Just so it didn't get lost in an old post...
I was in a rush when I replied last time and didn't have this to hand. Second
installment.
If you want a Bezier Spline approximation to an arc of a circle subtending angle
theta at the centre, the four control points are
(1,0), (1,a), (cos(theta) + asin(theta),sin(theta) -
acos(theta)),(cos(theta),sin(theta))
where a = (8/3)(sin(theta/2) - sin(theta)/2)/(1-cos(theta))
As mentioned before, this is tangent to the circle at theta/2 as well as the
endpoints and outside the circle otherwise.  For theta = pi/2 the defect is
0.03% of the radius. For theta = pi it is 1.8%, still not bad, but for theta =
5pi/4 it is an unusable 7.6%.
Tweaking a to have the spline cross the circle twice reduces the error only to
about 70% of the value given and is probably not worth it.
If anyone wants code for a single segment Bezier Spline sphere sweep, I will
post it again, since the last time was years ago.
Subject: Re: Bezier spline approximations to circles
Date: 25 Jan 2019 16:09:09
Message: <5c4b7af5$1@news.povray.org>
Hmmm.  This is the formula for 'a' that I used for the ring shank cross
section in GemCuts:
   #declare Gem__fn_Bezier_arc = function (x)
   { (8 * cos (x / 2) - 4 - 4 * cos (x)) / (3 * sin (x))
Presumably, they are somehow the same formula, though I haven't figured
out how to reduce one to the other.
My notes say that the curve deviates markedly from a circle if x > 90
degrees (pi / 2), though I did not quantify the error.
For large angles I just use 2 segments.
I've actually tried multiple crossings to approximate a quadrant of a
superquadric ellipse, but it required an arbitrary amount of fudging.  I
do not have a general formula for this.  I also tried using two 45
degree segments, but the result was horrible.
There are two Object Collection modules that already do this for
multiple segments: PointArrays and SphereSweep.
Date: 20 Feb 2019 09:10:01
Message: <web.5c6d5ef876c96ecec97227110@news.povray.org>
> section in GemCuts:
Sorry I'm a month late. I didn't spot your post. And you probably won't spot
this.
I plotted them in Matlab to convince myself they were the same. Then I
multiplied top and bottom by sin(x/2)/cos(x/2). 1+cos(x) is 2cos^2(x/2) and
1-cos(x) is 2sin^2(x/2).
Date: 20 Feb 2019 23:13:11
Message: <5c6e2557$1@news.povray.org>
>> section in GemCuts:
> this.
Good to know.  That's more trig than I can remember.
