POV-Ray : Newsgroups : povray.general : Spraypaint macro (see p.b.a for example) Server Time
24 Feb 2026 20:20:30 EST (-0500)
  Spraypaint macro (see p.b.a for example) (Message 1 to 1 of 1)
Subject: Spraypaint macro (see p.b.a for example)
Date: 1 Oct 2018 16:00:00
Message: <web.5bb27c2f74e67c79fd6b6fe10@news.povray.org>
The latest version of my spraypaint macro.  Example in p.b.a
Comments, Suggestions?
A.D.B.
#ifndef(SPRAYCAN_INC)
#declare SPRAYCAN_INC = version;
#ifdef(View_POV_Include_Stack)
   #debug "including spraycan.inc\n"
#include "rand.inc"
#include "math.inc"
#include "arrays.inc"
#declare PARTICLES = array[5000]
#declare PARTICLE_COUNT = 0;
#macro addParticle(LOCATION, INDEX)
    #declare PARTICLE_COUNT = PARTICLE_COUNT + 1;
    #if(PARTICLE_COUNT > dimension_size(PARTICLES, 1))
        Resize_Array(PARTICLES, dimension_size(PARTICLES, 1)+5000)
    #local PARTICLE = array[2] {LOCATION, <INDEX,0,0>}
    #declare PARTICLES[PARTICLE_COUNT - 1] = PARTICLE;
#macro reconstructFromFile()
  #local Ind = 0.0;
  #read(paintFile,Col)
  #ifndef(__IGNOREFILECOLOR__)
    #declare MyColor = Col;
  #while(defined(paintFile) & Ind <= TOTALITY)
    #read(paintFile,Loc,Ind)
    addParticle(Loc,Ind)
* Name: SprayCan                        Date: Oct 18, 2012  *
* Auth: Anthony D. Baye                                     *
* Vers: 2.0                                               *
* Desc: Creates a union from spheres scattered on a surface *
*    by using the trace() function. The pattern can be      *
*    limited by giving a pigment in the TEMPLATE slot.      *
* Args:                                                     *
*    OBJECT -> The environment to trace against.            *
*    TEMPLATE -> The pigment used to evaluate the pattern.  *
*         If no template is desired, use pigment { rgb 0 }. *
*    EPATH -> A spline delineating the path of the emitter. *
*    TPATH -> A spline delineating the path of the target.  *
*    FLOWRATE -> The number of particles per second.        *
*         A good value for a scale of 1 unit = 1 foot is    *
*         20000.                                            *
*    ANGLE -> Maximum angle for the spray cone.             *
*         with a statistically normal distribution, ~99.7%  *
*         of the particles should be inside this angle.     *
*    DURATION -> The number of seconds it takes to complete *
*         the path.                                         *
*    TOTALITY -> 0...1 inclusive. Mainly used for animation *
*         but can be used in single image mode as well.     *
*    File -> Name the file that the resulting object will   *
*         be saved in.  No extension required, .inc will be *
*         appended.  If no file is desired, enter "".       *
*         Cache file will be preferred if one exists, unless*
*         __FORCE_CREATE__ is defined.                      *
* Global Constants:                                         *
*    __FRAMERATE__ -> Set custom framerate. Default: 24fps  *
*    __FORCE_CREATE__ -> When defined, overrides default    *
*         behavior of preferring a cache file.              *
*         When the clock is running, this will cause the    *
*         cache to be rebuilt on the first frame only.      *
*    __SPRAYDEBUG__ -> Turn debug streams on when defined.  *
*    __IGNOREFILECOLOR__ -> Always use the color specified  *
*         in the macro call. Useful for experimenting with  *
*         colors, without rebuilding the pattern.           *
* Note: Even with optimizations, this macro can still take  *
*    several minutes to parse.                              *
//  Animation!
//  File now saves temporal data for each particle
//  Saved data is now in flatfile format as comma-separated values.
#macro SprayCan(OBJECT, TEMPLATE, EPATH, TPATH, Color, FLOWRATE, ANGLE,
DURATION, TOTALITY, FILE)
#local MyColor = Color;
#local extension = ".spr"
#ifndef(__FRAMERATE__)
  #local __FRAMERATE__ = 24;
#if((FILE != "" & !file_exists(concat(FILE, extension))) |
(defined(__FORCE_CREATE__) & (! clock_on | frame_number = initial_frame)))
  #declare doCreate = true;
  #debug "doCreate set to True.\n"
#else
  #declare doCreate = false;
  #debug "doCreate set to False.\n"
// A warning is needed in animation mode if the file has not been specified.
#if(FILE = "")
  #warning "SprayCan: Warning! No file specified, pattern will not be saved!\n"
#if(doCreate)
  #declare Slice_Delta = 1 / (DURATION * __FRAMERATE__);
  #local i = 0;
  #while(i < 1)
      #local pCount = 0;
      #while(pCount < FLOWRATE*Slice_Delta*DURATION)
            #local PHI = Rand_Normal(0.0, 0.33, RdmA)*(ANGLE/2);
            #local THETA = Rand_Normal(0.0, 1.0, RdmB)*180;
            #local _Z =  vnormalize(TPATH(i) - EPATH(i));
            #if(abs(vdot(_Z,z)) != 1)
                #local _X = vcross(_Z,z);
                #local _Y = vcross(_X,_Z);
            #else
                #local _X = x;
                #local _Y = y;
            #local _T = _X*sind(PHI)*cosd(THETA) + _Y*sind(PHI)*sind(THETA) +
_Z*cosd(PHI);
            #local _T = vnormalize(_T);
            // Begin trace
            #local _NORM = <0, 0, 0> ; // degenerate Normal vector.
            #local _START = EPATH(i) ; // The object starts here.
            #local Pos = trace (OBJECT, _START,  _T,  _NORM) ; // And comes to
rest here.
            // End trace
                #local dP = eval_pigment(TEMPLATE, Pos);
            #if( vlength( <dP.red, dP.green, dP.blue> ) = 0 )
                  addParticle(Pos, i)
      #local pCount = pCount + 1;
  #local i = i + Slice_Delta;
  #if(FILE != "")
    #fopen paintFile concat(FILE, extension) write
    #write (paintFile, concat("<" vstr(3, MyColor,",",0,6) ">,"))
#else
  #if(FILE != "")
    #fopen paintFile concat(FILE, extension) read
  #ifdef(__SPRAYDEBUG__)
    #debug concat("Loading paint data from file " FILE extension "...\n")
// TODO: Pattern should obey TOTALITY even when doCreate = true.
#declare Pattern =
union {
#for(i,0,PARTICLE_COUNT-1,1)
    #if(!doCreate | PARTICLES[i][1].x <= TOTALITY)
      sphere { PARTICLES[i][0], 0.001 }
    #if(doCreate)
      #ifdef(paintFile)
          #write(paintFile,concat("<"vstr(3,PARTICLES[i][0],",",0,6) ">,"
str(PARTICLES[i][1].x,0,10) ","))
    pigment { rgb MyColor }
#local Extents = concat("paint object extends from " vstr(3,
min_extent(Pattern), ", ", 0, 3) " to "
     vstr(3, max_extent(Pattern), ", ", 0, 3) "\n")
#ifdef(paintFile)
  #fclose paintFile
  #if(defined(__SPRAYDEBUG__) & doCreate)
    #debug concat("Spraypaint object saved in file \"" FILE extension"\"\n")
  #debug concat(str(PARTICLE_COUNT,0,1) " particles deposited.\n")
  #debug Extents
    Pattern
