POV-Ray : Newsgroups : povray.general : no_image behaviour Server Time
19 Apr 2024 22:10:07 EDT (-0400)
  no_image behaviour (Message 11 to 20 of 34)
Subject: Re: no_image behaviour
Date: 17 Jun 2018 16:15:00
Message: <web.5b26c0386d52b562635cc5ad0@news.povray.org>
hi,
> Am 17.06.2018 um 19:59 schrieb jr:
> > what does "primary" and "secondary" rays mean, in the context?  that is, in a
> > scene with only emissive media objects and zero light_source(s).
> Primary rays are rays traced (backward) from the camera into the scene.
> Seconary rays are rays traced (backward) from any "point of interest"
thank you for enumerating.  on first reading my idea is a no go.  :-(
will need time to re-read and try to understand the consequences.
regards, jr.
Date: 17 Jun 2018 19:46:15
Message: <5b26f2c7$1@news.povray.org>
Am 17.06.2018 um 22:10 schrieb jr:
> hi,
Whatever you're trying to accomplish; maybe if you let us know we might
be able to bounce some ideas ;)
Date: 17 Jun 2018 21:15:01
Message: <web.5b2707006d52b562635cc5ad0@news.povray.org>
hi,
appreciated, thanks.
"the idea" is very simple, I would like to animate some visible, emissive media
objects such that they move through other, not directly seen (contained) media.
the effect I'm after is that the additive effect of the differently coloured
media when intersecting should reveal the outline of the "hidden" objects
through the colour change(s).
hope that parses.  ;-)
regards ,jr.
Date: 18 Jun 2018 01:51:39
Message: <5b27486b$1@news.povray.org>
Am 18.06.2018 um 03:12 schrieb jr:
> hi,
I think it does.
Did you try using one `difference` and one `intersection` of the
container objects in question, with different media?
Or you could use one `merge` of the objects with the normal media "A",
and one `intersection` with a media "B-A" (IIRC you can have negative
emission, absorption or even scattering).
Date: 18 Jun 2018 06:20:00
Message: <web.5b2787176d52b562458c7afe0@news.povray.org>
No coffee yet...
Just to clarify - is anything visible while not intersecting, or do the rods
simply change color in the region where they intersect the invisible object?
You could define a separate container for the intersection color media by doing
an actual intersection {} with the rods and the invisible object.
If you define the container for the "normal" media as the difference {} of the
object from the rods, then I think you'll have what you want.
And those would be the only actual objects declared in the scene, made visible
by the intersection {} and difference {} directives.  Let's borrow from real
photography and call the #declares for the rods and invisible region "latent
objects".
I think you could then even scale the intersection by something near
(1-0.000001) to minimize coincident surfaces, if that's a problem.  It won't be
perfect - you'd to do an offset-curve to do that properly...
Date: 18 Jun 2018 07:33:24
Message: <5b279884$1@news.povray.org>
With v3.8 user_defined{} density is an option. The scene below does
something close to what you want - I think.
Bill P.
#version 3.8;
#default { finish {ambient 0.000 } }
#declare Grey20 = srgb <0.2,0.2,0.2>;
background { color Grey20 }
#declare Camera00 = camera {
     perspective
     location <3,3,-3.001>
     sky y
     angle 35
     right x*(image_width/image_height)
     look_at <0,0,0>
#declare White = srgb <1,1,1>;
#declare Light00 = light_source { <50,150,-250>, White }
#declare Red = srgb <1,0,0>;
#declare CylinderX = cylinder { -1*x, 1*x, 0.01 pigment { Red } }
#declare Green = srgb <0,1,0>;
#declare CylinderY = cylinder { -1*y, 1*y, 0.01 pigment { Green } }
#declare Blue = srgb <0,0,1>;
#declare CylinderZ = cylinder { -1*z, 1*z, 0.01 pigment { Blue } }
#declare SphereMediaContainer = sphere { <0,0,0>, 1 }
#declare SphereHidden = sphere { <0.2,0.1,0.2>, 0.3 }
#declare BoxForReveal = box { <-0.5,-0.5,-0.5>,<0.3,0.4,0.3> }
#include "functions.inc"
#declare FnSphereHidden = function {
     pattern { object { SphereHidden } }
#declare FnBoxForReveal = function {
     pattern { object { BoxForReveal } }
#declare FnZero = function (x,y,z) { 0 }
#declare Density00 = density {
     user_defined {
         function { FnBoxForReveal(x,y,z) },
         function { FnSphereHidden(x,y,z)*FnBoxForReveal(x,y,z) },
         function { FnZero(x,y,z) },,
#declare Media00 = media {
     method       3
     samples      100
     emission     rgb <1,1,1>
     density { Density00 }
#declare Clear100 = srgbt <1,1,1,1>;
#declare Texture00 = texture { pigment { color Clear100 } }
#declare Interior00 = interior { ior 1 media { Media00 } }
#declare Material00 = material {
     texture { Texture00 }
     interior { Interior00 }
#declare ObjectMediaContainer = object {
     material { Material00 }
     hollow
//--- scene ---
    camera { Camera00 }
    light_source { Light00 }
    object { CylinderX }
    object { CylinderY }
    object { CylinderZ }
    object { ObjectMediaContainer }
Date: 18 Jun 2018 08:55:01
Message: <web.5b27aac66d52b562635cc5ad0@news.povray.org>
hi,
no, not yet, the problem occurred with my first test trying.
wrt the CSG.  I need to sit down and digest all this, my naive original plan was
a simple animation involving more than one object moving, and the apparent need
to use CSG is .. a road block.  (it's becoming very complex, all of a sudden)
regards, jr.
Date: 18 Jun 2018 09:00:00
Message: <web.5b27abe96d52b562635cc5ad0@news.povray.org>
hi,
> No coffee yet...
the latter.
> You could define a separate container for the intersection ...
thank you for the pointers/ideas.  see my reply to clipka wrt CSG operations,
had not thought along those lines + now need to change course, so to speak.
cheers.
regards, jr.
Date: 18 Jun 2018 09:05:03
Message: <web.5b27ad0f6d52b562635cc5ad0@news.povray.org>
hi,
(scene code snipped)
wow, thank you for writing up a test scene.
alas, I haven't a 3.8 installed, but will now do that in the next few days.
care to recommend the "safest and most stable" :-)  of the alphas?
regards, jr.
Date: 18 Jun 2018 11:37:15
Message: <5b27d1ab$1@news.povray.org>
On 06/18/2018 09:01 AM, jr wrote:
> hi,
> regards, jr.
The latest 'Pre_release' has been good to me.
https://github.com/POV-Ray/povray/releases/tag/v3.8.0-alpha.9606898
Bill P.
