Sorry for too many questions. I am practising different possibilities of
POV-Ray, and text is very handy when combined with other objects.
I assume superellipsoid is similar to box in nature. Therefore, this code should
work
difference {
superellipsoid{ <1.00,0.25>
texture{ pigment{ color rgb<0.65,1,0.1>}
finish { phong 1}
text{ ttf "timrom.ttf", "text",0.3, 0
texture{ pigment{ color rgb<1,0.9,0.5>}
finish { phong 1 reflection 0.1}}
The render completes with no error and superellipsoid is drawn but not the text.
You need to scale it thicker to extend past the outer surface of the
superellipsoid
Then scale smaller in x/y and translate to center.
As a useful tool for future difference{}
make the "parent" object transparent (t~0.95)
make the subtractive child object a bright contrasting solid color.
Calculate the bounding boxes of the two objects and keep track of where they
truly are.
Make a union of the two objects to see that they will "work" in the difference
you envision.
THEN rewrite the scene as a difference, rather than a union.
(or do both, side-by-side)
{It would also be helpful to debug faster if you provide a completely renderable
scene - with camera location, etc.}
try this:
difference {
finish { phong 1}
text{ ttf "timrom.ttf", "text", 2, 0
scale 0.5
translate -x*0.3
translate -z*1
> superellipsoid
> truly are.
> you envision.
> try this:
> difference {
> finish { phong 1}
> scale 0.5
> translate -x*0.3
> translate -z*1
Wonderful! Works perfectly. Thank you very much.
