POV-Ray : Newsgroups : povray.general : text on superellipsoid Server Time
29 Sep 2024 00:17:20 EDT (-0400)
  text on superellipsoid (Message 1 to 3 of 3)
Subject: text on superellipsoid
Date: 28 May 2018 10:30:00
Message: <web.5b0c117642f2269f3ce674f0@news.povray.org>
Sorry for too many questions. I am practising different possibilities of
POV-Ray, and text is very handy when combined with other objects.
I assume superellipsoid is similar to box in nature. Therefore, this code should
work
difference {
superellipsoid{ <1.00,0.25>
  texture{ pigment{ color rgb<0.65,1,0.1>}
           finish { phong 1}
text{ ttf "timrom.ttf", "text",0.3, 0
      texture{ pigment{ color rgb<1,0.9,0.5>}
               finish { phong 1 reflection 0.1}}
The render completes with no error and superellipsoid is drawn but not the text.
Subject: Re: text on superellipsoid
Date: 28 May 2018 11:10:01
Message: <web.5b0c1ae9e3ae2cc710874a080@news.povray.org>
You need to scale it thicker to extend past the outer surface of the
superellipsoid
Then scale smaller in x/y and translate to center.
As a useful tool for future difference{}
make the "parent" object transparent (t~0.95)
make the subtractive child object a bright contrasting solid color.
Calculate the bounding boxes of the two objects and keep track of where they
truly are.
Make a union of the two objects to see that they will "work" in the difference
you envision.
THEN rewrite the scene as a difference, rather than a union.
(or do both, side-by-side)
{It would also be helpful to debug faster if you provide a completely renderable
scene - with camera location, etc.}
try this:
difference {
           finish { phong 1}
text{ ttf "timrom.ttf", "text", 2, 0
               scale 0.5
               translate -x*0.3
               translate -z*1
Date: 28 May 2018 11:20:00
Message: <web.5b0c1d4ce3ae2cc73ce674f0@news.povray.org>
> superellipsoid
> truly are.
> you envision.
> try this:
> difference {
>            finish { phong 1}
>                scale 0.5
>                translate -x*0.3
>                translate -z*1
Wonderful! Works perfectly. Thank you very much.
