POV-Ray : Newsgroups : povray.general : New User getting Parse Error Server Time
28 Mar 2024 17:45:07 EDT (-0400)
  New User getting Parse Error (Message 1 to 5 of 5)
Subject: New User getting Parse Error
Date: 2 Feb 2018 12:55:01
Message: <web.5a74a54a7b74b795bc980e590@news.povray.org>
Hi all!
I'm a relatively new user to Pov-Ray. I use it in conjunction with other
programs to generate scientific figures, so I have some mild experience, but
I've encountered an error that I'm not sure how to tackle.
The problem is as follows: I generate a Pov-Ray file successfully from one of
the programs I use, and I can open it in the editor without any issue. All the
commands are already present in the file so I should just be able to hit Run and
let it go.
However, while trying to parse the file, the program halts and I get the
following error: "Parse Error: Mesh face index out of range". This is
accompanied by a command line becoming highlighted in yellow, the "face_indices"
section of a mesh2 section.
I'm looking into the Mesh2 section of documentation, but I was wondering if
anyone out there could help me resolve this issue. Any help at all would be
extremely appreciated!
Subject: Re: New User getting Parse Error
Date: 2 Feb 2018 15:05:00
Message: <web.5a74c3cf8878a2e3c437ac910@news.povray.org>
Hi Paul - and Welcome!   :)
Usually when something's out of range (like in an array), you're trying to
access an element that hasn't been defined yet.
If there's a part of the mesh definition that lists how many faces, vertices,
etc - try incrementing that until the error goes away.
Then I'd investigate why the software gets it wrong.
Also, if you [ALT]-[M] to pull up the message window, and select Copy Pane, then
you can paste that here so we can see what the error is verbatim.
Date: 2 Feb 2018 21:00:14
Message: <5a7517ae$1@news.povray.org>
Am 02.02.2018 um 18:52 schrieb Paul:
This is an indication that whatever software created the file did a bad
job at it.
Date: 2 Feb 2018 22:45:00
Message: <web.5a752fbe8878a2e3a47873e10@news.povray.org>
About 'copy pane', from docs...
"Note: This command only appears if the currently selected window is the
Messages window." Then it shows up under the EDIT menu.
BTW, there are times when the message window is *completely* blank during an
entire POV-Ray session; it's happening right now on my Windows version of 3.7.1
beta 9. No idea why. It comes and goes.
All_Console=on
Verbose=on
(I'm not so sure those are working correctly either, when turned OFF-- I
generally still see some messages, when I'm expecting(?) not to.)
Date: 5 Feb 2018 04:15:00
Message: <web.5a781f818878a2e316086ed00@news.povray.org>
> job at it.
Yes, I hope this is not blender, is it?
If so, feel free to send me the blend file for debugging.
