POV-Ray : Newsgroups : povray.general : angry ini option problem Server Time
29 Sep 2024 02:17:08 EDT (-0400)
  angry ini option problem (Message 1 to 9 of 9)
Subject: angry ini option problem
Date: 10 Jan 2018 08:45:01
Message: <web.5a5616adc06758bc659f6d40@news.povray.org>
Early in the morning between coffee and jumping to work I changed a little
detail in my animation and rerenderd from the half. I made a typo and the ini
option was set to.
+kff125 +sf167
Everything went ok but it only rendered the useless frame 167. I think that
should throw an error or give a messagebox.
Preset INI file is 'P:\POV\INI\QUICKRES.INI', section is '[360p, No AA]'.
Preset source file is 'F:\Temp\light_test.pov'.
Rendering using command line '+kff125 +sf167'.
Rendering with 4 threads.
Parser Options
  Input file: F:\Temp\light_test.pov
  Remove bounds........On
  Split unions.........Off
  Library paths:
    P:\pov\include
    C:\Windows\Fonts
Animation Options
  Initial Frame:        1  Final Frame:      125
  Frame Step:           1
  Initial Clock:    0.000  Final Clock:    0.000
  Cyclic Animation.....Off  Field render.........Off  Odd lines/frames.....Off
Image Output Options
  Image resolution.....640 by 360 (rows 1 to 360, columns 1 to 640).
  Output file..........F:\Temp\light_test167.png, 24 bpp PNG
"F:\Temp\light_test.pov" line 40: Parse Warning: Clock = 1.339
Why set the parser Final Clock: 0.000 but still calculating the value after
Final Frame is reached.
System Win10 x64
Pov 3.7 RC 7 and 3.8 alpha
Subject: Re: angry ini option problem
Date: 10 Jan 2018 16:05:01
Message: <web.5a567ea752d0c7a2a47873e10@news.povray.org>
Even during a regular animation, Final Clock never changes from 0.000 in
'messages'-- which seems kind of odd. The running 'clock' value apparently isn't
coupled into the message stream, like it should(?) be-- if I understand the
meaning of Final Clock. It should at least show *something* different than
0.000, IMO.
Date: 10 Jan 2018 16:25:00
Message: <web.5a56841352d0c7a24f9671580@news.povray.org>
> 0.000, IMO.
Clock changes, if you set values for +ki and +kf. Even tried +kff10 +sf20 +ef30.
That would make sense if you want a different numbering of the output files. But
it doesn't work too.
Date: 10 Jan 2018 18:54:37
Message: <5a56a7bd$1@news.povray.org>
Am 10.01.2018 um 22:00 schrieb Kenneth:
> 0.000, IMO.
The values reported there are those (explicitly) set vial the `+ki` and
`+kf` options, /not/ those computed from the `kfi` and `kff` options.
Date: 10 Jan 2018 18:57:01
Message: <5a56a84d$1@news.povray.org>
> 0.000, IMO.
That *does* seem like a bug.
with +sf2753 +ef2753
Animation Options
   Initial Frame:        1  Final Frame:     3343
   Frame Step:           1
Frame step? I thought that was an uberpov thingy.
dik
Rendered 344576 of 345600 pixels (99%)
Date: 10 Jan 2018 20:50:01
Message: <web.5a56c19252d0c7a2a47873e10@news.povray.org>
dick balaska <dic### [at] buckosoftcom> wrote:
> Animation Options
>    Frame Step:           1
It's now in POV-Ray too (as of one of the 3.7.1 development versions, I think.)
Very handy too, for doing quick-and-dirty animation tests-- like rendering only
1 frame of each 10-frame group for example. Like key-framing.
Date: 10 Jan 2018 21:10:01
Message: <web.5a56c75e52d0c7a2a47873e10@news.povray.org>
Ah, I see now.
Given that fact, though, it nevertheless seems strange that leaving those out
(to invoke the default +ki of 0.0 and the default +kf of 1.0) produces a Final
Clock value of 0.000 instead of 1.000. That's kind of illogical... in my humble
opinion ;-)
Date: 11 Jan 2018 00:19:22
Message: <5a56f3da$1@news.povray.org>
>> Animation Options
>>     Frame Step:           1
Yes, very handy. My renderfarm can do a mosaic (6,3,8,2,5,10,1,4,7,9)
which is awesome, but I've always wanted it for scene development.
dik
Date: 11 Jan 2018 02:25:25
Message: <5a571165$1@news.povray.org>
Am 11.01.2018 um 03:09 schrieb Kenneth:
> Ah, I see now.
> opinion ;-)
The output there disregards default values, and really only shows the
values as set by the user.
Unfortunately, the output uses "0.000" as a placeholder for "not set",
which makes the output ambiguous. I might change that... if I find the time.
