POV-Ray : Newsgroups : povray.general : The question about of projected through option Server Time
16 Mar 2026 07:48:11 EDT (-0400)
  The question about of projected through option (Message 1 to 3 of 3)
Subject: The question about of projected through option
Date: 15 Dec 2017 07:30:00
Message: <web.5a33bf428bbfd557bde21ec0@news.povray.org>
There are two things I want you to ask for a favor.
I want to make the light source, which is positioned randomly between y=0~1 and
emits the light at the specific angle, 45 degrees. The light beam forms the
conical surface.
(Q1) Can I make this light source ?
I conceive that if the light through the torus (or the disk) is only rendering,
the above requirement can meet. So, I write the source code as follows, but the
pov-ray dose not work properly. It seems to be wrong with the "projected
through" option.
(Q2) What is wrong in my source code and how to  revise it ?
The pov-ray version is 3.7.
source code:
#include "textures.inc"
background{Black}
    location <0, -1, 0>
    right <-1.33, 0, 0>
    angle 40
    look_at <0, 0.5, 0>
 //Source
 #declare r2 = seed(12345);
 #declare I = 0;
 #declare number = 10;
 #while (I < number)
 #declare a = rand(r2);
 #declare Object1 = torus {
                            0.1, 0.05
                            sturm
                            translate <0, a-0.1, 0>
 light_source {
        <0, a, 0>
        color 100000
        projected_through {Object1}
#declare I = I+1;
Sincerely,
Masaki Yoneyama.
Subject: Re: The question about of projected through option
Date: 15 Dec 2017 10:17:11
Message: <5a33e777$1@news.povray.org>
Hello Masaki
And welcome
> conical surface.
Use a spotlight with the parallel keyword
> through" option.
To start with you need something for the light to shine on. So put a
plane with a texture in your scene. Below your camera so the light
shines on it.
When testing set your variable Number to 1. Also it is good practice to
capitalise your variables so they will not conflict with PovRay's own
variables.
Pull your camera back or use a wide angle to get a wider view.
I don't want to confuse things by supplying code as I use Left Handed
scenes with Y up. And changing coordinate systems confuses me.
But when I imported your scene into a modelling program. It looked like
you camera was pointing the wrong way if the plane was through the origin.
> source code:
> background{Black}
> camera {
>      location <0, -1, 0>
>      right <-1.33, 0, 0>
>      angle 40
>      look_at <0, 0.5, 0>
>   //Source
>   #declare I = 0;
>   #while (I < number)
>                              0.1, 0.05
>                              sturm
>   light_source {
>          <0, a, 0>
>          color 100000
> #declare I = I+1;
> #end
> Sincerely,
> Masaki Yoneyama.
Regards
Date: 16 Dec 2017 15:48:58
Message: <5a3586ba@news.povray.org>
> conical surface.
Yes.
> through" option.
> Sincerely,
> Masaki Yoneyama.
Use only a single light_source.
rgb 1e5 is extremely bright. You only use such a bright light when you
also use light fading with a short fade_distance.
Why place 10 lights? Their illumination bands will overlap.
You need some surface to get illuminated or some media to make the light
visible.
My proposition :
#declare R2= seed(frame_number);
//#declare R2= seed(12345678*clock);
//Make the seed change when using the animation feature
#declare V_Pos = rand(R2)
light_source{
  <0,V_Pos ,0>
  rgb 100000
		fade_power 2
		fade_distance 0.02
  projected_through{
	cylinder{<0,V_Pos-1,0><0,V_Pos-1.1,0>,1 open}
	//makes a thin cone
	//open used to remove the end caps
	//as we only want the side
plane{-z, -0.1 pigment{rgb 1} finish{brilliance 0}}
//Add something for the light to shine on
//and make it's illumination independent from the angle of incidence
Render with +kff 9 on the command line.
