On 31-12-2017 9:38, Chris Cason wrote:
> On 31/12/2017 19:32, Thomas de Groot wrote:
>> I am afraid, that did not help unfortunately.
> Do you have any extensions that could be interfering with loading of
> scripts from cse.google.com?
I don't know about that... ;_/
> If not, can you open your browser's debugging console (usually F12),
> select the 'network' tab, then reload the page? Check the network tab
> for any failed requests, and the console tab for any error messages.
You may judge from the attached. I am not familiar with this...
Download 'search2.jpg' (221 KB)
Preview of image 'search2.jpg'
The script loaded OK. Was there anything in the console tab?
-- Chris
Also please try the HTTPS version of the search page if you're using
HTTP, or the HTTP version if you're using HTTPS (it works on both for
me but as I notice you're using 'https everywhere' it's worth testing).
-- Chris
> http://www.povray.org/search/
> works for me. I searched color_map and got good results (and an amazon ad)
Works for me know. :-)
Regards
Ok. Back again, before closing down till next year.
On the console tab, there seems to be something not right (see image).
With https enabled or unabled, no difference.
Thanks so far Chris for your kind help. Have a good 2018 and see you
next year!
Download 'search3.jpg' (164 KB)
Preview of image 'search3.jpg'
Am 31.12.2017 um 13:19 schrieb Thomas de Groot:
The internerds say that the error message ("urchinTracker is not
defined") may be related to ad blockers.
urchintracker is used by google analytics; it should not have any
effect on the search (I tested search with my adblocker on and it
works fine even with urchintracker not being available).
Thomas: next time you are around, try launching your browser in safe
mode then try it again. If it works then we'll at least know it's
config-related.
-- Chris
Me too, running the latest Firefox. Thanks a lot, Chris!
Happy New Year to all!
> config-related.
Restarting Firefox (for Clipka: version 57.0.3 32 bits. Hey! that
should be 64 bits! My Win7 system is 64 bits) in safe mode makes the
problem disappear and the Search on the POV-Ray site works correctly.
>> config-related.
RIGHT! I solved the problem :-)
I told Ghostery to allow Google Analytics and Google Ajax Search API.
