POV-Ray : Newsgroups : povray.general : POVRAY memory usage Server Time
19 May 2024 02:56:48 EDT (-0400)
  POVRAY memory usage (Message 13 to 22 of 22)
Subject: Re: POVRAY memory usage
Date: 18 Oct 2017 00:50:00
Message: <web.59e6dd68da2c0257f749040@news.povray.org>
> "Taking advantage of POV-Ray's clever memory management for copies of meshes,
> this one has more than 12000 oak trees. "
> http://hof.povray.org/River.html
>  Are
> > there real renderings that need large numbers of objects allocated?
> http://hof.povray.org/fallfury.html
> This doodle alone consisted of 655,000 untextured spheres.
Question - what's the process for getting hold of the povray source files? Are
they available online somewhere? Do I contact the author?
Thanks,
Max
Date: 18 Oct 2017 04:45:20
Message: <59e714a0$1@news.povray.org>
Am 17.10.2017 um 21:27 schrieb Kenneth:
> "Bald Eagle" <cre### [at] netscapenet> wrote:
>> "Max" <max### [at] intelcom> wrote:
>>> Would povray be able to do more if memory were along the lines of 32GB
>> or larger for the average user?
>> YES.
> A naive question: Does POV-Ray actually choke on a larger-than-RAM-memory scene?
> I thought disc-swapping would take over (slower of course, but with no outright
> crash.)
It won't crash, but it will choke nonetheless, in that it will enter
swap hell. And on some operating systems, it will drag the whole OS with it.
Date: 18 Oct 2017 04:46:35
Message: <59e714eb$1@news.povray.org>
Am 18.10.2017 um 06:49 schrieb Max:
Just visit the public repository on GitHub:
https://github.com/POV-Ray/povray
Date: 18 Oct 2017 07:25:27
Message: <59e73a27$1@news.povray.org>
On 10/18/2017 12:33 AM, Max wrote:
> It seems povray crashes if the memory use gets larger than physical and virtual
> ram.
Don't do that then.
dik
Date: 18 Oct 2017 11:20:00
Message: <web.59e770d8da2c0257d983d9fd0@news.povray.org>
I must be blind - can you point me explicitly to the samples?
I see the samples in distribution/scenes/ and have looked through them, but I do
not see these hall of fame items.
Is there a public samples repository?
Thanks,
Max
Date: 18 Oct 2017 11:48:27
Message: <59e777cb$1@news.povray.org>
> Thanks,
I thought you meant the PovRay source code.
For the SDL scenes you will need to contact the author.
You might find that some of them have posted their scenes on their web
pages.
Regards
Date: 18 Oct 2017 11:53:42
Message: <59e77906$1@news.povray.org>
Am 18.10.2017 um 17:18 schrieb Max:
Sorry, misunderstanding - I thought you meant the source code of the
POV-Ray software.
I've now come to the conclusion that you really meant the POV-Ray
_scene_ files [for the POV-Ray hall-of-fame images mentioned earlier].
Date: 18 Oct 2017 17:07:12
Message: <59e7c280@news.povray.org>
>> crash.)
> ram.
> Max
It's not a hard crash, it's a fatal error condition that forces POV-Ray
to abort it's current operation.
Date: 18 Oct 2017 17:12:59
Message: <59e7c3db@news.povray.org>
> Thanks,
> Max
For the scenes source files, many are posted on p.b.scene-files. Those
that use large meshes are often missing them as they may be to large to
post.
If you look around, you can find the web pages of several authors, and
they frequently make their scene files available.
Date: 18 Oct 2017 17:30:01
Message: <web.59e7c7c2da2c0257355e45ab0@news.povray.org>
Yes. I'll contact the authors.
Thanks,
Max
