POV-Ray : Newsgroups : povray.general : guys could you help me out once more? Server Time
28 Mar 2024 19:58:31 EDT (-0400)
  guys could you help me out once more? (Message 1 to 10 of 10)
Subject: guys could you help me out once more?
Date: 21 Aug 2017 01:15:00
Message: <web.599a6b3a829a71901d2cb5f70@news.povray.org>
#declare numofpic = 100;
#declare shift = 1;
#declare X=numofpic;
#declare X5=array [X] { #for (i,0,numofpic^(1/2)[,shift]) i*shift, #end};
#declare Cam3 = camera {
  location <30,25-Y5[frame_number],5+X5[frame_number]>
  look_at  <0,10-Y5[frame_number],5+X5[frame_number]>
i don't care about the Y5,i think i can do that by myself if i knew how to make
X5.
X5 is like there should be 'numofpic' of numbers. for example
if numofpic is 100 and shift is 1,
X5 is like
{1,1,1,1,1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,3,3,3,3,3,3,3,3,3,3,```,10,10,10,10,10,10,10,10,10,10};
idk how to put the #for to array structure. plz help me. i appreciate.
Subject: Re: guys could you help me out once more?
Date: 21 Aug 2017 02:15:01
Message: <web.599a7a1761def543883fb31c0@news.povray.org>
> #declare shift = 1;
> X5.
> X5 is like
I think some clarification is needed:
* Is this your actual scene code, or is it just a condensed or abstract example?
* Which is more important to you, getting the ARRAY itself to work correctly, or
just getting CAM3 to work correctly? (The array may not be necessary.)
* In the #for loop, is 'numofpics' raised to the 1/2 power? (I.e., square root?)
It appears to be.
> X5 is like
Is this what your WANT the values in the array to be?
Date: 21 Aug 2017 10:15:01
Message: <web.599aea2961def543c437ac910@news.povray.org>
> #declare shift = 1;
> X5.
> X5 is like
So, it looks to me like you just want to populate your array with sets of 10
integers.
#declare N = 10;
#declare S = 1;
#declare X5 = array [101];
#for (Block, 0, N-1, S)
     #for (Val, 1, 10)
          #local Position = (Block*10)+Val;
          X5[Position] = Block;
     #end // end for Val
#end // end for Block
That ought to give you the general idea.
You can adapt this to use your total frame numbers and square root method, and
compactify it a bit by deleting the separate #local declaration, and embedding
the nested for-next loops _inside_ the array[N]{} declaration.
Date: 24 Aug 2017 00:40:00
Message: <web.599e57b261def543692574d10@news.povray.org>
> > #declare shift = 1;
> > X5.
> > X5 is like
> It appears to be.
> > X5 is like
it's actual code and i want to make this work
getting CAM3 to work correctly is more important for me.
if there're any other ways to move CAM3 like my code, it would be fine
yeah i want to make it square root.
if i wanna make 25 images, numofpic would be 25 and
CAM3 should move like this
1 2 3 4 5
6 7 8 9 10
11 12 13 14 15
16 17 18 19 20
21 22 23 24 25
Date: 24 Aug 2017 01:30:00
Message: <web.599e640561def543692574d10@news.povray.org>
#declare shift = 1;
#declare Y=numofpic;
{1,2,3,4,5,6,7,8,9,10,1,2,3,4,5,6,7,8,9,10,1,2,3,4,5,6,7,8,9,10,1,2,3,4,5,6,7,8,9,10,1,2,3,4,5,6,7,8,9,10,1,2,3,4,5,6,7
,8,9,10,1,2,3,4,5,6,7,8,9,10,1,2,3,4,5,6,7,8,9,10,1,2,3,4,5,6,7,8,9,10,1,2,3,4,5,6,7,8,9,10};
#declare Y5=array [Y]
{1,1,1,1,1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,3,3,3,3,3,3,3,3,3,3,4,4,4,4,4,4,4,4,4,4,5,5,5,5,5,5,5,5,5,5,6,6,6,6,6,6,6,6,6,
6,7,7,7,7,7,7,7,7,7,7,8,8,8,8,8,8,8,8,8,8,9,9,9,9,9,9,9,9,9,9,10,10,10,10,10,10,10,10,10,10};
  location <30,20-Y5[frame_number],5+X5[frame_number]>
  look_at  <0,10-Y5[frame_number],5+X5[frame_number]>                //
orthographic
this is the full code i originally made.
and i wanna make this as simple as possible.
i wanna change whole arrays by just changing shift and numofpic
Date: 24 Aug 2017 18:40:01
Message: <web.599f54cd61def543883fb31c0@news.povray.org>
> #declare shift = 1;
,7
6,
> orthographic
OK, I understand now what you're tryng to do with the camera. I've come up with
something that looks like it works-- on paper, anyway. The X-movement uses an
array, but the Y-movement does not.
#declare numofpics = 100;
#declare SQ = sqrt(numofpics);
#declare X5 = array[numofpics]
#declare AX = 1;
// to fill the array...
#for(i,0,numofpics - 1)
#declare X5[i] = AX;
#declare AX = AX + 1;
#if(AX > SQ)
#declare AX = 1;
#else
#declare YY = ceil(frame_number/SQ);
   location <30,20-YY,5+X5[frame_number]>
   look_at  <0,10-YY,5+X5[frame_number]>
 orthographic
However... You mentioned wanting to change the value of  numofpics.  But the
sqrt() trick will only work when  numofpics  has a square-root that is an
INTEGER-- like 64 (8), 81 (9), 100 (10), 121 (11), etc. Any of these will give
you a nice square grid of camera positions in X and Y.  Choosing a value like
150 will not.
I still don't understand what the meaning of 'shift' is; it's use in your code
isn't stated or obvious.
Date: 25 Aug 2017 03:05:01
Message: <web.599fcbb761def543883fb31c0@news.povray.org>
Oops, the camera should be like this instead-- because I made the array X5 to be
'zero-based', meaning the first value is held in array location X5[0], and runs
up to location X5[99]
   location <30,20-YY,5+X5[frame_number - 1]>
   look_at  <0,10-YY,5+X5[frame_number - 1]>
 orthographic
Date: 25 Aug 2017 08:10:01
Message: <web.59a0129c61def543c437ac910@news.povray.org>
> 150 will not.
I suppose you might be able to just round the sqrt calculation to give something
close and usable.
It seems he wants to use that to space out the positions - but I think that if
he's stepping through his for-next loop like that, that the high-bound value
will have to be adjusted by multiplying it by SHIFT, otherwise he'll run out of
array positions too soon, and won't get the number of frames that he really
wants.
Not to make it any more complicated, but it might give a more compact code -
what about calculating the array values by using abs(sin (somthing)), and that
way when [theta] goes past the max, it automatically goes back to 0, and the y
array can be calculated as int(theta/360)*SHIFT.
Date: 25 Aug 2017 08:50:00
Message: <web.59a01bfe61def543c437ac910@news.povray.org>
Actually, now that the coffees have started to kick in, a mod(A,B) function
would probably be better.
Date: 25 Aug 2017 12:25:01
Message: <web.59a04de161def543883fb31c0@news.povray.org>
> way when [theta] goes past the max, it automatically goes back to 0...
Yes, I see what you're getting at; very clever. I wouldn't have thought of it.
The only (temporary) trouble I see is that the sin wave has to jump back to zero
when it reaches its PEAK-- then a new positive sin wave needs to begin again
immediately. Etc. OR... the 'descending' part of the (positive) wave needs to
have its values reversed, so that the 'peak' is considered 'zero', and the array
values *increase* as the wave falls back to zero. (This would be for creating
the 2nd group of repeating X-array values.) Then the wave scheme starts over
again.
If either of these scenarios could be made to work, it would be an elegant
solution-- more beautiful than my 'brute-force' #for loop. ;-)
I still like my YY equation, though; seems to be rather compact and elegant
as-is (unless the OP just *wants* to use an array for the Y-values as well.)
