POV-Ray : Newsgroups : povray.general : a really dumb mistake Server Time
17 May 2024 11:01:38 EDT (-0400)
  a really dumb mistake (Message 11 to 14 of 14)
Subject: Re: a really dumb mistake
Date: 25 Aug 2017 15:10:00
Message: <web.59a07598d9dfcaaec437ac910@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> In the 16th century, the Inquisition would have burned Clipka at the stake, as a
> warning to other such Necromancers :-P
21st.   Other than that, you're probably right.
Orwell just had the date wrong.
https://campus.aynrand.org/works/1943/01/01/the-soul-of-an-individualist/page1
https://duanegraham.files.wordpress.com/2012/07/s-e-cupp-rand-quote.jpg
Date: 11 Sep 2017 10:40:01
Message: <web.59b69f36d9dfcaaec437ac910@news.povray.org>
> Challenge accepted ;)
> #declare MY_VALUE = 10;
> #for(C,1,19)
>   #debug concat("\n","My Value = ",str(MY_VALUE,1,0),"\n")
>   #declare MY_VALUE = 43-MY_VALUE;
> #end
So, I looked further into this, since it was so elegant,
and I came across this discussion, and further suggested improvement:
https://stackoverflow.com/questions/18941019/simplest-way-to-toggle-a-integer-variable-between-two-values
( ^= operator is the XOR operator)
"Another way is to toggle an index between 0 and 1 and index an array with that:
int main() {
    int const values[] = {0x55, 0xaa};
    int selector = 0;
    selector ^= 1;                // toggle index
    int value = values[selector]; // select value
This is also future-resistant. If in the future OP wants to round-robin between
3, 4, or N values, just add to the array and change selector ^= 1 to selector =
(selector+1)%N."
I'm unfamiliar with the bitwise operators in POV-Ray, so interpreting the docs
is a bit unclear to me.
"bitwise_xor(A,B,...)
Bitwise XOR of two or more float values considered as integers."
This would make a sweet little macro for people to use in lots of future scene
files - so good, it should be in one of the standard include files.
I might try to code it up tonight, unless someone beats me to it   ;)
Date: 11 Sep 2017 13:50:05
Message: <web.59b6cc01d9dfcaaec437ac910@news.povray.org>
or over lunch  :D
Like so:
#macro CycleValues (_Array, _Counter)
 // Round-robin cycle through N values
 // Bill Walker September 2017
 #local N = dimension_size (_Array, 1);
 #local selector = mod (_Counter, N);
 // selector will range from 0 to N-1
 // Return the value in _Array corresponding to _Counter
 _Array [selector]
#end // end macro CycleValues
#declare RoundRobin = array [4] {2, 5, 9, 13};
#for (i, 0, 10)
 #declare Value = CycleValues (RoundRobin, i);
 #debug concat ("Array value for i=", str(i, 2, 0), " is ", str(Value, 3, 0),
"\n")
#end // end for i
Date: 11 Sep 2017 17:18:00
Message: <59b6fd88$1@news.povray.org>
Am 11.09.2017 um 19:46 schrieb Bald Eagle:
> or over lunch  :D
> Like so:
>  _Array [selector]
> #for (i, 0, 10)
> "\n")
> #end // end for i
Invoking a macro in a loop? Can't imagine this to be of any use in terms
of efficiency ;)
