POV-Ray : Newsgroups : povray.general : re Cassini Server Time
16 Mar 2026 11:18:11 EDT (-0400)
  re Cassini (Message 1 to 10 of 24)
Subject: re Cassini
Date: 27 Apr 2017 10:25:01
Message: <web.5901ff37711d262c437ac910@news.povray.org>
Just throwing this out there in case someone wanted to jump on a fun project /
resurrect an old one, before I did:
It would be fun to render / animate Saturn and its rings ---- with a Monolith in
full view   :D
Preferably by someone named Dave.
Because then we could all say, "Just what do you think you're doing, Dave?"
and
"That's a very nice rendering, Dave. I think you've improved a great deal. Can
you hold it a bit closer?"
Subject: Re: re Cassini
Date: 27 Apr 2017 10:44:24
Message: <590203c8$1@news.povray.org>
> full view   :D
> and
I'm on it.
I started a month ago working on an Earth - Moon orrery animation with
Saturn in the background.
Nothing to show yet as I'm modelling it in Blender and haven't rendered
it with PovRay yet.
One problem is that the image maps I have are uniform across the the X
axis. So show no rotation on the planet or rings. :(
I'm having the usual problems you get with orreries. Scale and scale.
Regards
Date: 27 Apr 2017 10:51:06
Message: <5902055a$1@news.povray.org>
> it with PovRay yet
But this gives an idea of the layout. As you can see there is still a
bit to do. Animate the gears and get the clouds to display properly.
https://youtu.be/7yAYTllKCic
Regards
Date: 27 Apr 2017 12:40:01
Message: <web.59021e5b981bf41cc437ac910@news.povray.org>
Oh my - that ought to be a fairly complex project  :O
I somehow haven't thought of tackling one of those yet - though my apple peeler
is closely related  ;)
It brings to mind the one in Pitch Black, and the truly awesome one in The Dark
Crystal.
and then there's _this_ guy:
http://zeamon.com/wordpress/?page_id=526
> it with PovRay yet.
Ah Blender.   Lots of buttons.  :D
I had done a quick seach for povray saturn, and there may be some older Saturn
ring projects you might make good use of.
Good work - nice job on the gears  :)   Are they 'simple' gears or true
involutes?
Date: 27 Apr 2017 13:33:12
Message: <59022b58@news.povray.org>
It is more of a Blender learning experience.
Actually not so much so. I've taken so long because when I made an
accurate gear train. You could not see the detail when it was animated.
So I cite Artistic licence and will pockle it. ;)
Hmm! an apple peeler. That sounds interesting. If you have a partially
peeled apple that would be more difficult. I would say.
Images? :)
> Crystal.
I wish I watched films, I feel out of touch. :)
Yes, that is nice. I would not mind having one of those at home. :D
>> it with PovRay yet.
And shortcuts. Thank goodness it is my fingers that do the remembering. :)
The image map I used for the rings was a cut down version of Bjorn
Jonsson's from when PovRay only had a maximum of 256 entries. That
limitation has been removed. So when I write the PovRay textures I'll
have better textures. His planet textures have more detail.
> involutes?
The planetary gears are true involutes but they are a lot of work so for
speed the others are simple, for the moment.
Regards
Date: 27 Apr 2017 15:15:02
Message: <web.590242d7981bf41cc437ac910@news.povray.org>
> Images? :)
Indeed, but that would give me a good bit to think about   ;)
I will post the current state of the WIP over in pbi.
I will have to cajole and shame my friend to make one with the laser cutter...
Yes, those were the ones I was thinking of.
They are a lot of work to get set up initially - it took me forever to get them
figured out, coded, and converted to SVG to test on the laser cutter.
Date: 27 Apr 2017 16:30:48
Message: <590254f8$1@news.povray.org>
>> Images? :)
I would if I could. :)
It took me a while to find it again.
Have a look at this site. I know it's for Blender but there are
calculators to help with the equations.
http://www.otvinta.com/index.html
Regards
Date: 27 Apr 2017 17:01:28
Message: <59025c28$1@news.povray.org>
> full view   :D
Funny you should mention this.  I made a Saturn animation exactly 12
years ago to the day.
I have posted it in p.b.a.
Date: 4 May 2017 13:25:07
Message: <web.590b63c5981bf41cc437ac910@news.povray.org>
Stephen,
What are you using to determine your gear tooth numbers?
Did you start from scratch, use existing plans, or some sort of gear train
calculator?
(I have piles and piles of plastic gears - I was wondering about finding the
best / approximately correct arrangement of the ones I have available.)
Date: 4 May 2017 16:42:10
Message: <590b9222$1@news.povray.org>
On 5/4/2017 6:24 PM, Bald Eagle wrote:
> Stephen,
You do ask awkward questions. ;-)
> calculator?
Basically I use my fingers and integer arithmetic. Although a s/sheet
helps. First you work out the final ratio which in that case was 28:1.
28 revs of the earth in the same time that the Moon rotates once. (To
keep the same face pointed towards the earth.) So it is number of teeth
on the input gear to number of teeth on the output. But since I did not
want to build all the bearings and supporting structure. I used a
planetary gear chain. That uses specific ratios and diameters for the
gears and I got them from this site: http://www.otvinta.com/index.html
After all that it was a wasted effort because it was indistinct and I
might as well have use textures. So following the Animators guidelines I
cheated and made sure that the gears meshed and no one would be able to
tell it was not accurate. Smoke and mirrors. ;) The mind is easily fooled.
Best for what application? Remember when using compound gear chains the
ratios are multiplied.
This is mostly from memory. I only did mechanical engineering at high
school and that was a long time ago. So that is what I meant about doing
it on my fingers. One step/gear at a time. ;-)
If I have not answered your question. Ask again.
Regards
