POV-Ray : Newsgroups : povray.general : Povray features Server Time
29 Sep 2024 08:16:52 EDT (-0400)
  Povray features (Message 1 to 10 of 15)
Subject: Povray features
Date: 14 Sep 2016 07:20:01
Message: <web.57d931929276064baf131fa80@news.povray.org>
Hello there. My name is Ivano Arrighetta and I'm Italian.
I would like to know more about povray used with FFMPEG and imagemagick
and in detail:
1) Can it capture images from scanner and/or webcam?
2) Can it do OCR?
3) Can a 2D surface be extruded?
4) Can a raster image be used as a sound? (maybe like a spectrum or so)
5) Can it do vector animations?
6) Can it generate 3D geometry?
7) Can it add 3D modifyers? (like twist, tape, bend, etc)
8) Can it synthesize audio?
9) Can it capture audio from a microphone?
10) Can it convert an audio stream to a raster image?
11) Can it capture a video from webcam or the desktop?
12) Can a video be used as a texture for a 3D surface?
Thanks in advance for any help.
Bye, Ivano.
Subject: Re: Povray features
Date: 14 Sep 2016 08:10:00
Message: <web.57d93d85aa83bb045cf7fc420@news.povray.org>
So after a little research I found answers to most questions.
The only 2 questions still unanswered are:
1) Can a raster image be used as a sound? (maybe like a spectrum or so) (I don't
know)
2) Can a video be used as a texture for a 3D surface? (I don't know)
Bye, Ivano.
Date: 14 Sep 2016 08:39:49
Message: <57d94515@news.povray.org>
Am 14.09.2016 um 14:07 schrieb Berserk:
> know)
Since POV-Ray doesn't use sounds, the obvious answer is "No" -- not as
far as POV-Ray itself is concerned.
You may find external pieces of software that can convert images to
sounds, but that's an entirely different thing then.
There used to be experimental code to use frames of a video as textures,
but that code is currently defunct. You'd have to export the video as a
series of images, render the scene as an animation that loads the
corresponding image for each frame, and finally convert the resulting
sequence of images to a video again.
Date: 14 Sep 2016 08:45:00
Message: <web.57d9462faa83bb04c1055b8c0@news.povray.org>
After some research I found answers to most of my questions.
Here are unanswered questions:
no
2) Can it do OCR?
3) Can it do vector animations?
4) Can it import and export 3D geometry? (like .obj or so)
don't know
2) Can it capture audio from a microphone?
3) Can a video be used as a texture for a 3D surface?
Note these questions are not about Pov-Ray alone, but used with FFMPEG, SoX and
ImageMagick.
Bye, Ivano.
Date: 14 Sep 2016 09:10:01
Message: <web.57d94b98aa83bb04844d19a00@news.povray.org>
Sorry for too much posting.
The only unanswered question remaining is:
1) Can a video be used as a texture for a 3D surface?
Bye, Ivano.
Date: 14 Sep 2016 09:26:11
Message: <57d94ff3$1@news.povray.org>
    Somethink like that ?
           http://la.buvette.org/vrac/composite.avi
Date: 14 Sep 2016 10:16:16
Message: <57d95bb0$1@news.povray.org>
Not directly using only POV, no.
But as clipka already said, you can convert the video to a series of
image files using an external program (I use avisynth, but there are
surely others).
In your POV scene, when rendering the animation, you then select which
image to load based on the time.
Date: 14 Sep 2016 12:10:01
Message: <web.57d975c9aa83bb04b488d9aa0@news.povray.org>
That is wicked cool.
A very nice effect that probably took a lot of work to get to work, and likely a
lot of rendering and post-processing time to make into the full animation.
Very nice work.
Date: 14 Sep 2016 12:50:01
Message: <web.57d97ee7aa83bb04f7739dda0@news.povray.org>
Thanks everyone for the replyes.
Date: 14 Sep 2016 13:30:01
Message: <web.57d987e8aa83bb04f7739dda0@news.povray.org>
Yes, exactly
