POV-Ray : Newsgroups : povray.general : Sweeping circle along catenary curve Server Time
25 Feb 2026 06:21:58 EST (-0500)
  Sweeping circle along catenary curve (Message 1 to 3 of 3)
Subject: Sweeping circle along catenary curve
Date: 28 Apr 2016 14:55:00
Message: <web.57225c575b2354ee292a95ac0@news.povray.org>
(One day old to povray)
I want to render catenary wires (will assume them to be plain in texture)
There's an old, but useful thread for rendering catenary chains here
http://news.povray.org/povray.binaries.images/thread/%3Cweb.42f332855de03cffa196ebe30%40news.povray.org%3E/
I modified the code, and basically instead of torus links, with alternating 90
degree rotation, I made them cylindrical with no rotation. However this is a
naive way to extrude.
How can I do this? Basically use polygon
sweep(http://www.povray.org/documentation/view/3.6.2/62/) along an array of 3D
points got by solving for a catenary
Subject: Re: Sweeping circle along catenary curve
Date: 29 Apr 2016 22:11:25
Message: <5724144d@news.povray.org>
If you want a simple, plain, wire, then you can use the sphere_sweep
primitive.
If you use the cubic_spline, you use the code to generate points
starting one step before the first point and ending one step after the
last point. As the cubic_spline interpolation give you a smooth curve,
you don't need many points, something like 10 to 20 points should be
enough in most cases.
Check the documentation about sphere_sweep.
Date: 5 May 2016 10:30:01
Message: <web.572b57bc7cac95668bfd5e7f0@news.povray.org>
> primitive.
> Alain
Hey thanks for the help. Before I saw this, I came across a rope macro and
modified that heh
http://news.povray.org/povray.binaries.images/thread/%3C4a1e679e@news.povray.org%3E/
