POV-Ray : Newsgroups : povray.general : At wits' end Server Time
22 Dec 2025 22:04:17 EST (-0500)
  At wits' end (Message 1 to 10 of 24)
Subject: At wits' end
Date: 13 Mar 2016 18:55:01
Message: <web.56e5eeb4332c3703fd6b6fe10@news.povray.org>
I've been staring at this problem for several hours now, and I can't figure out
what is going on.
I'm working with some fractal patterns in C++, and I was trying to model the
math in povray (I'll post the source below)
The pattern is fairly simple: take a line segment and replace it with three
segments of length L/sqrt(7) where L is the length of the original segment.
this is the axiom for a gosper island. the end segments should make an angle of
asin(sqrt(3)/(2*sqrt(7))) with the original segment and all three segments,
naturally, should have a length of L/sqrt(7)
L: 2.267787   // sanity check calculated before calling gosper_axiom(...)
len: 6.000000    // length of p1 - p0 calculated by macro
vTlen: 1.000000  // normalized length (just what it should be, but making sure)
newlen: 2.267787 // calculated length of segments
np1: -0.7014146472,0.7014146472  // new point 1
np2: 0.7014146472,-0.7014146472  // new point 2
// Second iteration, calculated using above values for p0 and np1
len: 2.403222    // should be 2.267787
vTlen: 1.000000  // correct, naturally.
newlen: 0.908333 // suspect value, given above problems
// these values are obviously not what I was expecting given the first iteration
// and render result.
np1: -0.3507073236,0.3507073236
np2: 0.3507073236,-0.3507073236
So if anyone can tell me what I'm doing wrong below, I'll be grateful.
A.D.B.
#version 3.7;
global_settings { assumed_gamma 1.8 }
#include "math.inc"
light_source { <0.0, 0.0, -10.0> rgb 1 }
 perspective
 location <0.0, 0.0, -10.0>
 up y
 right x*(image_width/image_height)
 look_at <0.0, 0.0, 0.0>
#default {
    pigment { Orange }
    finish { ambient 0 diffuse 0.7 }
#macro vec2rot(V, A)
    #local _X_ = -V.u*cos(A)*sin(A) - V.v*cos(A)*sin(A);
    #local _Y_ = V.u*sin(A)*cos(A) + V.v*sin(A)*cos(A);
    #local RESULT = <_X_,_Y_>;
    RESULT
#macro gosper_axiom(p0, p1)
cylinder { p0, p1 0.0078125 }
#local V = p1 - p0;
#local vT = vnormalize(V);
#local len = vlength(V);
#debug concat("len: "str(len,0,6) "\n")
#debug concat("vTlen: "str(vlength(vT),0,6) "\n")
#debug concat("newlen: " str(len/sqrt(7),0,6) "\n")
#local np1 = (len/sqrt(7))*vec2rot( vT,asin(sqrt(3)/(2*sqrt(7))));
#local np2 = (len/sqrt(7))*vec2rot( vT,-asin(sqrt(3)/(2*sqrt(7))));
#debug concat("np1: " vstr(2,np1,",",0,10) "\n")
#debug concat("np2: " vstr(2,np2,",",0,10) "\n")
union {
    cylinder { p0, np1 0.0078125 }
    cylinder { np1, np2 0.0078125 }
    cylinder { np2, p1 0.0078125 }
        pigment { Red }
#declare TH = degrees(asin(sqrt(3)/(2*sqrt(7))));
#declare L = 6.0/sqrt(7);
#debug concat("L: " str(L,0,6) "\n")
gosper_axiom(<-3.0, 0.0>, <3.0, 0.0>)
gosper_axiom(<-3.0, 0.0>,<-0.7014146472,0.7014146472>)
Subject: Re: At wits' end
Date: 13 Mar 2016 22:05:01
Message: <web.56e61b6e509d798c5e7df57c0@news.povray.org>
If you could perhaps provide a diagram of how you get those proportions and
angles, then maybe I could help you faster.
It's a bit harder to work out starting from first principles.   ;)
Date: 13 Mar 2016 22:20:00
Message: <web.56e61fc4509d798c5e7df57c0@news.povray.org>
Not sure if this helps at all, but I diagrammed out what I could, based on
http://www.mathstat.concordia.ca/faculty/pgora/m475/Gosper%20Island.html
and
http://www.fractalcurves.com/Root7.html
I'll post it in binary images.
That ought to give some basis for proportions and angles.
Looks like you've got L (black line), L/2, S (hexagon side), S/2, 90 deg, 60
deg, 120 deg, 45 deg, 15 deg, 75 and 95 deg (on either side of the orange line)
to work with.   Plus whatever relationships there are with hexagons with lines
from center to vertices or edge midpoints.
I've been banging my head on stuff here all day, so I'm probably calling it
quits for the night.   I'll check in the morning and see if you figured it out,
or if you can give me something to take up and run with.
Date: 13 Mar 2016 22:25:02
Message: <web.56e620e2509d798c5e7df57c0@news.povray.org>
Posted.
http://news.povray.org/post/?url=http%3A%2F%2Fnews.povray.org%2F
Date: 13 Mar 2016 22:30:00
Message: <web.56e6214b509d798c5e7df57c0@news.povray.org>
> Posted.
Maybe that ought to be:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.56e620c88e79eb4c5e7df57c0%40news.povray.org%3E/
:O
Date: 13 Mar 2016 22:40:00
Message: <web.56e62410509d798cfd6b6fe10@news.povray.org>
> "Bald Eagle" <cre### [at] netscapenet> wrote:
> > Posted.
> :O
hmmm... your math differs from the site I was using for information.
As for the logo solution, I've done it that way before.  This is something else
I wanted to try.
And it still doesn't explain the strange floating-point error I get out of the
vec2rot macro.  I've narrowed it down to that particular spot: The vector I get
out of that macro does not conform to the angle I give it.
A.D.B.
Date: 14 Mar 2016 00:10:00
Message: <web.56e6395f509d798cfd6b6fe10@news.povray.org>
> > > Posted.
> > :O
> I wanted to try.
> Regards,
> A.D.B.
Also, that right angle you have there doesn't make a 45-degree angle with L/2
the rise is sqrt(3)/2 or sin(60), the run is 0.5 (half the side length) +
sin(30) ==> 1 so atan(sqrt(3)/2)) ~= 40.8934 degrees which makes the upper
(downward) angle ~= 49.1066 degrees.
A.D.B.
Date: 14 Mar 2016 01:00:00
Message: <web.56e64487509d798cfd6b6fe10@news.povray.org>
> > > > Posted.
> > > :O
> > I wanted to try.
> > Regards,
> > A.D.B.
> Regards,
> A.D.B.
which makes that scalene section 19.1066:120:40.8934
regards,
A.D.B.
Date: 14 Mar 2016 04:13:23
Message: <56e672a3$1@news.povray.org>
Two mistakes...
>      RESULT
> #end
This is wrong, should be:
     #local _X_ = V.u*cos(A) - V.v*sin(A);
     #local _Y_ = V.u*sin(A) + V.v*cos(A);
     RESULT
You seem to have made it too complicated, it's just a 2D rotation:
https://en.wikipedia.org/wiki/Rotation_matrix#In_two_dimensions
These are wrong, should be:
#local np1 = p0 + len/sqrt(7)*vec2rot( vT,asin(sqrt(3)/(2*sqrt(7))));
#local np2 = p1 - len/sqrt(7)*vec2rot( vT,asin(sqrt(3)/(2*sqrt(7))));
np1 is at p0 plus the distance len/sqrt(7) times your new direction.
np2 is at p1 *minus* the distance len/sqrt(7) times the new direction.
Date: 14 Mar 2016 06:48:46
Message: <56e6970e$1@news.povray.org>
>> :O
His diagram lines are OK, but some of the angles are wrong. Actually so
long as you know the angles of a hexagon (120 degrees), just use
Pythagoras on the lower left triangle (the one with hypotenuse L/2).
(L/2)^2 = (S/2 + S*sin(30))^2 + (Scos(30))^2
(L/2)^2 = (S/2 + S/2      )^2 + 3/4*S^2
(L/2)^2 = 7/4 * S^2
  L^2    = 7 * S^2
  L      = sqrt(7) * S
