POV-Ray : Newsgroups : povray.general : Omni-directional Stereo Content Server Time
18 May 2024 09:57:03 EDT (-0400)
  Omni-directional Stereo Content (Message 45 to 54 of 54)
Subject: Re: Omni-directional Stereo Content
Date: 9 Mar 2016 15:12:28
Message: <56e083ac@news.povray.org>
Le 06/03/2016 15:49, clipka a écrit :
> Y'all might want to try the latest and greatest POV-Ray development release:
> https://github.com/POV-Ray/povray/releases/tag/v3.7.1-alpha.8509766%2Bav119
> It adds a new function-based user-defined camera:
>     camera {
>       user_defined
>       location {
>         FUNCTION, // x-coordinate of ray origin
>         FUNCTION, // y-coordinate of ray origin
>         FUNCTION  // z-coordinate of ray origin
>       direction {
>         FUNCTION, // x-coordinate of ray direction
>         FUNCTION, // y-coordinate of ray direction
>         FUNCTION  // z-coordinate of ray direction
>       CAMERA_MODIFIERS
> where each FUNCTION takes the screen coordinates as parameters, ranging
> from -0.5 (left/bottom) to 0.5 (right/top).
It's nice, but it is not generic enough:
you cannot have a non-traced area, like for fisheye and omnimax camera.
Yep, give me a finger, I would take the arm to the elbow... of the other side, with a
leg or two.
(where to I put the whole collection of smileys ?)
Date: 9 Mar 2016 16:29:46
Message: <56e095ca@news.povray.org>
Am 09.03.2016 um 21:12 schrieb Le_Forgeron:
>>     camera {
>>       user_defined
>>       location {
>>       direction {
>>       CAMERA_MODIFIERS
a leg or two.
Ooooh -- I can give you _the_ finger if you like:
To identify regions that should be left untraced, simply have the
`direction` functions all return 0. :P
Date: 9 Mar 2016 17:35:00
Message: <web.56e0a45e976329954e8811590@news.povray.org>
My current ODS user_defined camera (side-by-side only):
#declare odsIPD = 0.065;
#declare odsLocationX = 0;
#declare odsLocationY = 0;
#declare odsLocationZ = 0;
#declare odsDirectionX = 0;
#declare odsDirectionY = 0;
#declare odsDirectionZ = 1;
      user_defined
      location {
        function { odsLocationX + cos(select(x,(x+0.5)*2,(x*2)) * 2 * pi -
pi)*odsIPD/2*select(x,-1,1) }
        function { odsLocationY }
        function { odsLocationZ + sin(select(x,(x+0.5)*2,(x*2)) * 2 * pi -
      direction {
        function { sin(select(x,(x+0.5)*2,(x*2)) * 2 * pi - pi) * cos(pi / 2 -
(1-(y+0.5))*pi) }
        function { sin(pi / 2 - (1-(y+0.5))*pi) }
        function { cos(select(x,(x+0.5)*2,(x*2)) * 2 * pi - pi) * cos(pi / 2 -
(1-(y+0.5))*pi) }
I want to complete it and clean/optimize it, maybe useful in docs as example if
it deserves.
- In original Google docs formula about ODS, there isn't any reference about the
starting location and direction of the camera.
  The above code render always in forced direction <0,0,1>.
  Anyone can help me about where to place the odsDirectionX,Y,Z unused
variables? I don't know almost nothing about 3d maths...
- There is a function that return a float component from a given Vector?
  I aim to write
  #declare odsDirection = <0,1,1>
  and in function
  odsLocation.X
  because i'm forced to have six function that return float for location and
direction,
  or i can write two function that return a Vector?
Date: 21 Mar 2016 22:00:01
Message: <web.56f0a5e6976329954e8811590@news.povray.org>
Hi to all, some update on this topic.
I done a lot of test, and, for me, the Google ODS docs:
https://developers.google.com/cardboard/jump/rendering-ods-content.pdf
are simply wrong (i mean the raytracing suggested algorithm).
I write a mail (i'm still waiting for a feedback) to Mach Kobayashi, that seem
related to the work:
https://community.renderman.pixar.com/article/991/rendering-for-vr.html
This .pov source: http://pastebin.com/aPbGSDud
generate this image with the Google ODS formulas:
http://www.clodo.it/host/images/f6febe4d2a5739483562719923fc528c31ac378b.png
With my Oculus Rift, the front and bottom view are perfect, but looking
left and right the 3D seem reversed.
Focus on the little 4 yellow balls (front, left, right, bottom).
Look here, i manually draw yellow lines:
http://www.clodo.it/host/images/50ca1ff17fc834e167d44c0ab24484acd90bfd3f.jpg
From what i understand, on top (left eye) image, yellow ball need to
stay always at right of the yellow line.
So, i rewritten the ODS with another logic:
// ODS, Top/Bottom
#declare odsIPD = 1;
#declare odsAngle = 90;
      user_defined
      location {
select(-y,-1,+1)*odsIPD/2*cos(-pi+2*pi*(x+0.5+odsAngle/360))}
select(-y,-1,+1)*odsIPD/2*-sin(-pi+2*pi*(x+0.5+odsAngle/360))}
      direction {
        function {  sin(((x+0.5+odsAngle/360)) * 2 * pi - pi) * cos(pi / 2
-select(y, 1-2*(y+0.5), 1-2*y) * pi) }
        function {  sin(pi / 2 - select(y, 1-2*(y+0.5), 1-2*y) * pi) }
        function {  -cos(((x+0.5+odsAngle/360)) * 2 * pi - pi) * cos(pi / 2
-select(y, 1-2*(y+0.5), 1-2*y) * pi) * -1}
I removed the Google ODS ray_origin formulas.
user_defined location function X it's in range -0.5..0.5, and in panoramic mean
So i used it to rotate the IPD vector <-/+IPD,0,0> around Y axis.
Now it's correct:
http://www.clodo.it/host/images/66a61ebcd04180d9203276741ad78075262d20a3.jpg
and look perfectly in all direction with Oculus Rift.
Here:
https://forums.oculus.com/viewtopic.php?f=28&t=30854
there are some updated sample rendering.
I'm almost ready to build a POV-Ray Wiki page about ODS, i need only to write
user_defined function for side-by-side and single-eye versions.
Date: 22 Mar 2016 05:54:46
Message: <56f11666$1@news.povray.org>
Am 22.03.2016 um 02:55 schrieb Clodo:
That's no surprise, because in the camera direction Z-axis formula you
have a surplus "-1" factor at the end that's /not/ in the original
Google formulae.
If this is intended to compensate for a left-handed vs. right-handed
coordinate system, you need to apply the same factor to the camera
location Z-axis formula.
> Now it's correct:
That depends on what spatial orientation you originally aimed for;
removing the surplus "-1" factor gives a different result, flipping the
handedness and looking in the -Z direction rather than the +Z direction.
My suggestion would be to go back to the original Google ODS formulas,
and use a factor "Handedness" rather than a constant "-1" (also, make
sure to use the factor on both Z-axis formulae), which can then be set
to either "-1" for left-handed or "1" for right-handed.
Date: 22 Mar 2016 07:15:00
Message: <web.56f12898976329954e8811590@news.povray.org>
> Google formulae.
Ouch. Caused by my incompetence in 3D math... i'm a software security expert,
i'm working on ODS only for fun.
Reverted to the original Google ODS:
// ODS - Top/Bottom
#declare odsIPD = 0.065; // Interpupillary distance
#declare odsHandedness = -1; // "-1" for left-handed or "1" for right-handed
#declare odsAngle = 0; // Rotation, clockwise, in degree.
      user_defined
      location {
        function {  odsLocationX + cos(((x+0.5+odsAngle/360)) * 2 * pi -
pi)*odsIPD/2*select(-y,-1,+1) }
        function {  odsLocationZ + sin(((x+0.5+odsAngle/360)) * 2 * pi -
pi)*odsIPD/2*select(-y,-1,+1) * odsHandedness }
      direction {
-select(y, 1-2*(y+0.5), 1-2*y) * pi) * odsHandedness }
The GOOD news for me: this generate pixel per pixel the same image of my
rewritten version of yesterday night.
So, the function above seem the release candidate for the Wiki page. I will
prepare the equivalent side-by-side and single-eye.
Thanks, thanks, thanks for your feedback.
Date: 3 Apr 2016 14:25:00
Message: <web.57015f36976329954e8811590@news.povray.org>
I write a post on my blog about all my ODS experiments with POV-Ray:
https://www.clodo.it/blog/omni%C2%ADdirectional-stereo-ods-with-pov-ray/
The post contain the latest edition of ODS user_defined camera.
I hope that can be the final version, and my experiment can be useful to anyone
as starting point to explore this subject.
Any of my works can be used as public-domain, for example if POV-Ray team want
to use as sample in docs or wiki.
I still think that ODS will deserves a C++ user-friendly implementation in
POV-Ray codebase. A lot of video contents are under development around the
upcoming VR market.
Ciao!
Fabrizio Carimati / Clodo
Date: 3 Apr 2016 15:37:55
Message: <57017113$1@news.povray.org>
Nice text. Really very cool.
You provide the fast setting as quickres.ini... I would have liked:
* also the various scenes for the above illustrations (if anybody want to make them
again), as downloadable links (no need to display them online)
* maybe instead of adding to quickres.ini, another file name ? (such as easyods.ini ?)
(just a suggestion)
> upcoming VR market.
The best I could do was adding omni_directional_stereo camera to my own fork
(hgpovray).
It does not have the limitation of camera's direction of your text. (as well as right
& up that can be adjusted too).
Did you see it ?
About the vertical modulation, it was not in the original paper.
Is it now a requirement to have some vertical modulation ?
One of the link (Oculus VR Camera) seems to indicate that the modulation (start and
curve) could
be different for nadir and zenith (each its own settings)
Also on the same link, there is the nvidia cube and 3x2 cube map (in addition to
Longitude+latitude projection),
are there any use or interest for them ?
Do they also need a modulation for nadir & zenith ? (seems so, but I always like
contributions)
Date: 7 Apr 2016 06:10:00
Message: <web.57063067976329954e8811590@news.povray.org>
Thanks! Note that i'm not english native, and i'm not a math or 3d expert, i'm a
software security expert (ddos, XSS, VPN, stuffs like that). I made this ODS
only for fun.
I will do.
?) (just a suggestion)
Ouch, i simply don't know the multiple .ini files feature :P
(hgpovray).
right & up that can be adjusted too).
> Did you see it ?
No sorry, never tried, i will look soon.
curve) could
It's not a requirement.
But it's an HELL write a user_defined camera function.
Use a odsVerticalModulation of 0.0001 pratically generate the same image we can
obtain without any vertical modulation. So i prefer to not add other select() in
the user_defined formula.
I read a lot about the nadir/zenith issue. But same as above, it's a pain add
different method/params on user_defined function. Much easy in C code.
But i don't know if my patch will be accepted in povray official code, so i
prefer to maintain identical the user_defined function and my C code.
From what i understand, software like 3DS Max, Maya, Softimage etc use
DomeMaster, that apply a simple texture to filter that.
At the end, it's a limit of ODS, and content creator need to avoid object at
nadir/zenith. I prefer to avoid additional complexity of user_defined functions
right now.
contributions)
Theory VS practice. I own an Oculus Rift and soon a Vive. Pratically there isn't
any image/video player that support cubemap, or are very very rare. For this
reason, i don't know anything about that.
There are a lot of website that share video/image for HMD, i never seen a
cubemap format, always omnidirectional (Stereo or Mono).
I'm working on another project right now, but i hope soon to test your hgpovray
fork.
Ciao!
Date: 17 May 2016 10:55:00
Message: <web.573b304b97632995625bbade0@news.povray.org>
The following 4K 60fps ODS animation took 3 weeks to render on my Thinkpad X200:
  https://www.youtube.com/watch?v=7bvMaKAcAlQ
