POV-Ray : Newsgroups : povray.general : installing 'experimental builds' of POV-Ray-- question Server Time
26 Sep 2024 23:55:51 EDT (-0400)
  installing 'experimental builds' of POV-Ray-- question (Message 1 to 8 of 8)
Subject: installing 'experimental builds' of POV-Ray-- question
Date: 15 Jan 2016 17:30:01
Message: <web.569971ed85ba3b8133c457550@news.povray.org>
I just downloaded the latest 'experimental build' of POV-Ray, from here (for my
Windows computer)...
https://github.com/c-lipka/povray/releases/tag/v3.7.1-alpha.8431463%2Bav74
I want to make sure that I'm installing it correctly (I downloaded the sse2
version):
It was originally compressed using the '7z' method, so I uncompressed it using
the 7zip app. The only item found in the new folder is the POV-Ray 'engine'
file...  pvengine32-sse2
I understand that it needs to (temporarily) replace v3.7's already-installed
engine file-- which is here (on my machine)... "C:\Program
Files\POV-Ray\v3.7\bin\pvengine32-sse2.exe"
So I moved the *original* pvengine32-sse2 file into a dummy temporary folder
there first (to hide it), then placed the new engine file in the 'bin' folder.
This seems to work OK, but is there any 'hidden detail' that I've neglected to
do? I just want to make sure that I've done the install correctly. Comments?
Subject: Re: installing 'experimental builds' of POV-Ray-- question
Date: 15 Jan 2016 20:05:05
Message: <56999741@news.povray.org>
Am 15.01.2016 um 23:26 schrieb Kenneth:
> version):
You've done it precisely the way it's supposed to be done (except that
the official recommendation would be to rename the original .exe, but
moving it to a different directory serves the exact same purpose just as
well).
Date: 16 Jan 2016 00:15:01
Message: <web.5699d0ca9d3fad1933c457550@news.povray.org>
Thanks! I'm looking forward to trying out the latest fixes and features.
Date: 16 Jan 2016 01:10:00
Message: <web.5699de0a9d3fad1933c457550@news.povray.org>
You might want to add a note on your download page that the #version number in a
scene needs to be changed to #version 3.71 rather than the 'standard' 3.7, to
make use of the newest features. Of course, that might be obvious to others here
on the newsgroups; but it temporarily fooled me  :-0
Thanks for the hard work you've done!
Date: 16 Jan 2016 03:07:02
Message: <5699fa26$1@news.povray.org>
One thing you will notice right away, if you use backslashes to separate
folders in file names, is a list of parse warnings. It is good policy to
replace them with forward slashes, and it does not influence parsing in
lower versions of POV-Ray.
Date: 16 Jan 2016 04:30:00
Message: <web.569a0c819d3fad1933c457550@news.povray.org>
Thanks, Thomas; I didn't know that.
Date: 16 Jan 2016 14:23:17
Message: <569a98a5@news.povray.org>
> version):
This looks good.
Another possibility would be to create a new folder, named something
like /Experimental/, and run the experimental version from there.
You can create a distinct shortcut to the experimental version if you wish.
Uberpov use this aproatch.
Date: 16 Jan 2016 14:55:55
Message: <569aa04b$1@news.povray.org>
Am 16.01.2016 um 20:23 schrieb Alain:
Um... no, UberPOV /per se/ doesn't; the "standard" UberPOV release is
intended to be copied into the same folder as your POV-Ray binary. It
just uses a different filename.
There /is/ a stand-alone release of UberPOV, but that one goes even
further, not only installing into an entirely separate binary folder,
but also using different registry keys, a different folder for include
and sample files, a different master .ini file name, and other such
stuff. Plus, it doesn't even need official POV-Ray to be installed.
