POV-Ray : Newsgroups : povray.general : A newbie request Server Time
26 Sep 2024 23:49:50 EDT (-0400)
  A newbie request (Message 1 to 3 of 3)
Subject: A newbie request
Date: 7 Dec 2015 18:45:01
Message: <web.566619718c133f205259f0910@news.povray.org>
I would appreciate a simple walk-thru on how to do this. I have a good quality
bitmapped file which I wish to project onto a plane, so that a cylindrical
mirror (at right angles) will view it correctly view it. I would appreciate any
setup assistance. This is for a wedding present for my step-daughter and her new
husband, to see a reflection of a piece of calligraphy which they cherish. I
would like a setup so that I can input my image, vary the angle of view, and
render the projection.
I am using the current Windows version of Pov-Ray on Windows 7 Pro, but am quite
used to command-line operation of programs.
Thanks in advance for any assistance!
Bill
Subject: Re: A newbie request
Date: 8 Dec 2015 15:02:25
Message: <56673751@news.povray.org>
> Bill
When you place an image, it's 1 unit whide and tall in the x-y place
extending infinitely along the z axis. You need to scale it to your
need. If the image is not square, your scaling must take that into
account. If the image have a 4:3 aspect ratio, the scalling can be
something like scale<1, 3/4> or scale<4/3, 1> or scale<4,3>,...
Normaly, it repeat itself verticaly and across to cover the whole plane.
Unsing the once keyword limit it to a single instance.
Start with a simple plane: plane{-z,0}
Add your image this way:
pigment{image_map{bmp Your image}scale 10 once}
Your image now reside with one corner at 0,0 spaning 10 units up and to
the right.
Assuming that the area for the mirror is in the middle top side:
cylinder{<5,10,0><5,10,-20>, Radius_Of_The_Mirror
	texture{
		pigment{rgb 0}
		finish{ambient 0 diffuse 0 reflection 1}
If the place for the mirror is elsewhere, you need to place the cylinder
in that location.
Another possible location is in the middle of the image, so, at 5,5 in
this case.
It now look like:
union{
  plane{-z,0
   pigment{image_map{bmp Your image}scale 10 once} finish{emission 1
ambient 0 diffuse 0}
   texture{
    pigment{rgb 0}
rotate 90*x
The rotate makes the plane horizontal.
Now, you only need to place the camera. Something like:
camera{location<5, -20, 5 look_at<5, 0, 10>}
The camera should look at the base of the mirror or some place along it.
The area outside the image will be black.
This example don't use any light but use a light emiting finish to make
things visible.
Date: 8 Dec 2015 17:00:25
Message: <566752f9$1@news.povray.org>
> Bill
Hi Bill,
Your task caught my interest so I played with code on and off today - my
daughter got married just over a year ago and I used POV-Ray to create
table place cards for the reception. For what I worked up see the
povray.binaries.images newsgroup for the post "Anamorphic images for
mirrored cylinder."
http://news.povray.org/povray.binaries.images/message/%3C56674f14%40news.povray.org%3E/#%3C56674f14%40news.povray.org%3E
-------------- Other information.
One povray user I recall doing this kind of work and more with povray
was fdecomite, not sure if currently active but see:
https://www.flickr.com/photos/fdecomite/sets/72157604984910048/ for a
large image gallery.
An article showing various ways to create the distorted images -
including a pointer to free canned software for the job - can be found at:
https://anamorphicart.wordpress.com/2010/04/21/cylindrical-mirror-anamorphoses/
The latter article uses povray to the view the resultant image on a
mirrored cylinder which I suppose to be similar to the set up Alain
offered a bit ago.
Bill P.
