POV-Ray : Newsgroups : povray.general : source code pow function Server Time
17 Apr 2026 10:15:33 EDT (-0400)
  source code pow function (Message 1 to 4 of 4)
Subject: source code pow function
Date: 8 Aug 2015 01:50:01
Message: <web.55c5982ff3c2e99c2aaea5cb0@news.povray.org>
Does the source actually use the default power function from the cmath library?
It seems to me that I heard the default algorithm was actually somewhat
inefficient.
Please correct me if I'm wrong.
A.D.B.
Subject: Re: source code pow function
Date: 8 Aug 2015 09:42:08
Message: <55c60730$1@news.povray.org>
Hash: SHA256
> cmath library?
Where ? in the SDL or function in the SDL, or internally ?
In the SDL, yes, it's mapped to whatever the math library provide for
pow().
In function, yes too.
Internally, oh yes!
> somewhat inefficient.
All that is rumour so far. You vaguely heard that it would be vaguely ..
If you are referring to something like
http://stackoverflow.com/questions/9652549/self-made-pow-c
(second answer, with POW(a,b) = EXP(LOG(a)*b) ) it's a trick that
works only :
1. on float of 32 bits
2. with Ieee-757 representation normalised value
(Remember that such float only provide 6 to 7 significant digits)
That's a non-portable optimisation which does not even handle corner
situation (when the number is denormalized due to the encoded value,
or NaN... ).
BTW, the OP of LOG also assumed that int type is at least 32 bits...
oh the hard delusion on some architectures (this year (2015), I still
have to handle a modern chip (or rather SoC) with int of 16 bits: its
natural size (it can do 64 bits, but it costs more))
> Regards, A.D.B.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlXGBy8ACgkQhKAm8mTpkW1XFgP+KZ/ASzfUBzPXFw0gHoXKBixQ
RoSLXuvheJsJRQpTaqi3d5mijMsn32ARnwTIvtyUPy/ehJKQXgdcLOIYNSKcDDgO
E5SwKnJnqAgxuWsWJCz4kKG2TjAkiFtEhuj8DRK5YaUFhIW8lxJyncToJZgjCcMK
6hohRLifjF0NAachrwg=
=mdFT
-----END PGP SIGNATURE-----
Date: 8 Aug 2015 13:20:00
Message: <web.55c639b3617576822aaea5cb0@news.povray.org>
Le_Forgeron <jgr### [at] freefr> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA256
> > cmath library?
> pow().
> Internally, oh yes!
No need to get snippy.  I remember having to write a fast exponentiation
function for a class once.  It's been a while.
> works only :
> or NaN... ).
So, even using the double versions for pow and exp doesn't necessarily improve
anything?
I'm just asking questions.  I can't learn (much) if I don't ask questions.
A.D.B.
Date: 9 Aug 2015 14:25:33
Message: <55c79b1d$1@news.povray.org>
Am 08.08.2015 um 07:48 schrieb Anthony D. Baye:
To be precise, POV-Ray uses the "pow()" function declared in the
standard <cmath> header file; what library this function is implemented
in depends on the compiler and runtime environment.
For instance, and AFAIK, when compiling with Microsoft Visual Studio the
function is implemented in the "tran.lib" library, while on Unix systems
it is implemented in a library called "libm".
> inefficient.
That may well be: The default algorithm needs to fit certain precision
constraints, /and/ be somewhat efficient in /all/ cases, so it is
inevitable that there are cases in which a less-precise or less-generic
algorithm would suffice and be faster.
Also, it may depend on the actual math library linked to, and/or the CPU
architecture on which it is executed.
That said, the total time POV-Ray spends executing calls to pow() is
probably far too low to warrant spending any energy on trying to figure
out which of those calls can be replaced with a faster implementation.
By far, most exponentiation in raytracing is squaring and taking the
square root, for which POV-Ray already uses specialized functions
(currently the "x*x" idiom in the case of squaring, and the sqrt()
function from <cmath> for taking the square root).
Likewise, looking at the SDL pow() function, POV-Ray spends far more
time parsing the SDL statement than it does actually computing the result.
Bottom line: Optimization /may/ be possible, but I strongly suspect it's
not worth bothering. I presume it isn't even worth bothering to examine
whether it is worth bothering.
