POV-Ray : Newsgroups : povray.general : brightnessproblem Server Time
14 Jan 2026 22:06:33 EST (-0500)
  brightnessproblem (Message 1 to 3 of 3)
Subject: brightnessproblem
Date: 20 Feb 2015 13:55:01
Message: <web.54e7823dc066c0c89cbd5880@news.povray.org>
Hello all, I have the following code (easy one)
  location  <0.0, 2.5, -10.0>
  look_at   <0.0, 0.0,  0.0>
light_source {
  0*x                  // light's position (translated below)
  color rgb <1,1,1>    // light's color
  translate <-50, 40, -50>
/*cylinder that works as ground*/
cylinder { <0,-60,0>,<0,0,0>, 20
           texture { pigment { color rgb<0.77 , 0.4, 0.13> }
           scale <1,1,1> rotate<0,0,0> translate<-2,0,-20>
/* front wall*/
 plane{
 z, 90
 pigment {color /*rgb<1,1,0>*/ blue 1}
Ok, everything is ok until here. But when I add the following figure, all the
colors of the picture become brighter! Somebody can tell me why?
The code I add, and mess up everything is this one:
#include "shapes3.inc"
declare g1 = union{
object {Segment_of_CylinderRing( 1.0, // major radius,
                                 0.60, // minor radius,
                                 0.40, // height H,
                                 180  // angle (in degrees)
        texture{ pigment{ color /*rgb<0.6,1,0>*/ red 1}
                 finish { phong 0.0 reflection 0.00}
               } // end of texture
        scale <1,1,1> rotate<90,0,-50> translate<0,1,0>
object{ Segment_of_CylinderRing( 1.70, // major radius,
                                 1.3, // minor radius,
                                 0.40, // height H,
                                 85  // angle (in degrees)
               } // end of texture
        scale <1,1,1> rotate<90,0,222>  translate<-1.35,2.86,0>
declare g2 = union {
object {Segment_of_CylinderRing( 2.0, // major radius,
                                 1.60, // minor radius,
                                 0.40, // height H,
                                 160  // angle (in degrees)
               } // end of texture
        scale <1,1,1> rotate<90,0,160> translate<-0.78,1.63,0>
object{g1}
declare gota_final = difference {
 object{g2}
cylinder { <0,0,0>,<0,0,2.00>,1.3
           texture { pigment { color /*rgb<0.6,1,0>*/ red 1}
                   //normal  { bumps 0.5 scale 0.005}
                     finish  { phong 0.0 reflection{ 0.00 metallic 0.00} }
                   } // end of texture
           scale <1,1,1> rotate<0,0,0> /*translate<-1.5,2.85,-1>*/
translate<-1.5,2.82,-1>
         } // end of cylinder  ------------------------------------
  scale <0.5,0.5,0.5>
  rotate <0, -20, 0 >
object{gota_final translate <-1.2, 0.2, -3.6>}
Subject: Re: brightnessproblem
Date: 20 Feb 2015 16:10:00
Message: <web.54e7a28fce37c802664dfe080@news.povray.org>
> camera {
> light_source {
> /* front wall*/
>  plane{
>  z, 90
> declare g1 = union{
>                                  0.40, // height H,
>                } // end of texture
>                                  0.40, // height H,
>                } // end of texture
>                                  0.40, // height H,
>                } // end of texture
> object{g1}
>  object{g2}
>                    } // end of texture
>   scale <0.5,0.5,0.5>
>   rotate <0, -20, 0 >
hi
missing "}" for closing texture in first cylinder
to avoid  brigth change insert "#version=3.7" at the beginning of the file
povray automatically add "assumed_gamma 1.0" but "shapes3.inc" in your case add
"#version=3.6" declaration
Date: 21 Feb 2015 07:45:01
Message: <web.54e87d16ce37c80289cbd5880@news.povray.org>
Thank you!
