POV-Ray : Newsgroups : povray.general : Candy ior? Server Time
27 Sep 2024 03:14:35 EDT (-0400)
  Candy ior? (Message 1 to 7 of 7)
Subject: Candy ior?
Date: 13 Feb 2015 03:20:01
Message: <web.54ddb32f24a1ea9de2b2ab920@news.povray.org>
What's the ior for glucose sweets(hard candy)? like Beacon Sparkles or candy
rolls. I haven't been very successful in getting a realistic candy render.
-Nekar Xenos-
Subject: Re: Candy ior?
Date: 13 Feb 2015 04:11:40
Message: <54ddbfcc$1@news.povray.org>
> -Nekar Xenos-
It seems that 84% sucrose solution in water has ior about 1.5 (whereas
water is 1.33), so solid sugar might be around 1.5 to 1.56.
Now the problem might be the laminated sugar on sweets: you might have
to model an opaque core within a surrounding sugar coating.  And here
come the problem of coincident inner surface (not a problem, just no
inner surface for the coating)
the coating might be about a millimetre deep. Remember to increase
max_trace_level.
I wonder if the Subsurface scattering can be used to model that instead.
Just because nobody complains does not mean all parachutes are perfect.
Date: 13 Feb 2015 12:15:58
Message: <op.xtz98rxbufxv4h@xena.home>
On Fri, 13 Feb 2015 11:11:39 +0200, Le_Forgeron <lef### [at] freefr> wro
te:
r
>> candy
>> render.
>> -Nekar Xenos-
> max_trace_level.
d.
Thanks, Le Forgeron,
I didn't consider the sugar coating. Subsurface scattering might be
overkill. Or it might just be the thing that makes it look more realisti
c.
-Nekar Xenos-
Date: 13 Feb 2015 20:44:34
Message: <54dea882@news.povray.org>
> On Fri, 13 Feb 2015 11:11:39 +0200, Le_Forgeron <lef### [at] freefr> wrote:
>>> or candy
>>> render.
>>> -Nekar Xenos-
>> max_trace_level.
> overkill. Or it might just be the thing that makes it look more realistic.
Clear candy coating, or clear candy, should be transparent and don't
need subsurface scattering.
If you want an opaque candy, then, subsurface scattering looks like it's
a must.
Date: 14 Feb 2015 01:50:00
Message: <web.54deefa0bbabcce390bea60c0@news.povray.org>
> a must.
> Alain
It has to be transparent. I think Le Forgeron was talking about the slight matt
finish on candy.
-Nekar Xenos-
Date: 15 Feb 2015 17:46:29
Message: <54e121c5@news.povray.org>
>> a must.
>> Alain
> finish on candy.
> -Nekar Xenos-
For a slight mate finish, just use a mate finish: lowish and broad
highlights, medium-low and blurred reflection should do the trick.
Date: 16 Feb 2015 11:20:00
Message: <web.54e21806bbabcce35e7df57c0@news.povray.org>
Depending on what sort of hard candy you're modeling, it may be perfectly
translucent, or it may have air-bubble inclusions in the form of bubbles in the
case of cast candies like lollipops, or the long striations of stretched
candies.
Also, there is likely to be a very thin coating of wax or mineral oil to provide
gloss and prevent sticking to the wrapper.
https://www.youtube.com/watch?v=M-_CaDRD7jQ
