Say I have a macro that returns values:
#macro someMacroReturningAValue(params)
#local _RESULT = foo;
// do stuff here...
_RESULT
I can use this macro in a computation, thusly:
object { bar translate someMacroReturningAValue(params)*x }
but I cannot set the macro as the rValue of a declaration, like so:
#declare blah = someMacroReturningAValue(params);
because povray doesn't see the semicolon at the end of the declaration. I can
add the semicolon inside the macro, and the declaration works, but the first
usage breaks.
in order to make the declaration work without breaking the first usage, I have
to encapsulate the macro call in parentheses:
#declare blah = (someMacroReturningAValue(params));
Which, obviously, forces the macro to be evaluated first, but I have no idea why
it makes a difference, and it makes for a very confusing error.
Any explanations?
A.D.B.
> // do stuff here...
> _RESULT
> #end
The below code runs fine here, does it work ok on your installation?
What are you doing differently (eg what is "params" defined as?). Can
you produce just a few lines that others can run to reproduce the problem?
#local _RESULT = params * 2;
_RESULT
#local p = 1;
#declare blah = someMacroReturningAValue(p);
> > // do stuff here...
> > _RESULT
> > #end
> _RESULT
> #end
> #local p = 1;
hallo
this fail
#declare rndx=seed(123);
#macro rnr(nrx,mii,mxx)
#if(mii>=0)
(rand(nrx)*(mxx-mii+1)) + mii
#else
mii+(mxx-mii)*rand(nrx) ///////// LINE 40
#local d=0;
#local d=rnr(rndx,-20,20);
line 40: Parse Error: All
#declares of float, vector, and color require semi-colon ';' at end if the
language version is set to 3.5 or higher. Either add the semi-colon or set the
language version to 3.1 or lower.
Fatal error in parser: Cannot parse input.
Render failed
this work ok
#if(mii>=0)
#else
#local d=<0,0,0>;
#local d=<rnr(rndx,-20,20),0,0>;
Am 17.01.2015 um 02:05 schrieb eticre:
> this fail
> #if(mii>=0)
> #else
> #end
> #end
> #local d=0;
This is a known issue rooted deep in the current parser (and not due to
be fixed before implementation of a brand new parser); to work around,
first assign the expression to a local variable, then finally "return" that:
#if(mii>=0)
#local result = (rand(nrx)*(mxx-mii+1)) + mii;
#else
#local result = mii+(mxx-mii)*rand(nrx);
result
The issue reported by the OP, however, is that this construct allegedly
doesn't always seem to work either; but for the time being I presume
that Anthony accidently did something wrong.
> > this fail
> > #if(mii>=0)
> > #else
> > #end
> > #end
> > #local d=0;
> #if(mii>=0)
> #else
> #end
> result
> #end
I could have been certain that I did exactly this, but I suppose that
considering the complexity of what I was working on, there was something I
missed.
my simple test, also works for both cases:
#version 3.7;
light_source { <5, 10, -30> rgb 1 }
perspective
location <0.0, 0.0, -10.0>
up y
right x*(image_width/image_height)
look_at 0
#macro mrav(V)
#local result = V;
// stuff and junk...
result
#declare myval = mrav(5);
sphere { 0.0 0.125 pigment { rgb 1 } translate mrav(5)*x }
A.D.B.
