POV-Ray : Newsgroups : povray.general : 16bits per color. why is my gold dithered & posterized at 4K resolution? Server Time
31 Oct 2024 21:22:56 EDT (-0400)
  16bits per color. why is my gold dithered & posterized at 4K resolution? (Message 1 to 3 of 3)
Subject: 16bits per color. why is my gold dithered & posterized at 4K resolution?
Date: 4 Jan 2015 03:40:01
Message: <web.54a8fc5022a9a84e8694a3930@news.povray.org>
                color rgb <251.0/255*BRIGHTNESS, 230.0/255*BRIGHTNESS,
1.0/255*BRIGHTNESS>//nice bright gold color I picked using ps's color picker
                //color rgb <233.0/255, 157.0/255,211.0/255>
            finish {
                phong 0.9
                phong_size 60
                //roughness 0.02
                brilliance BRILLIANCE
                specular .75
                roughness .1
                //roughness .001
                ambient 0.5
                diffuse 0.1 //.1
                //ambient 0.2
                //diffuse .3 //.1
                ////reflection {.3}
                reflection {
                    //rgb <233.0/255/3, 157.0/255/3, 211.0/255/3>, rgb
<233.0/255, 157.0/255, 211.0/255>//nice bright gold color I picked using ps's
color picker
                    fresnel on
                    metallic 1.0
                    //brilliance BRILLIANCE
                reflection 1
                conserve_energy
                //metallic  1.0
                specular 0.9
        interior {
            ior 2.4
            fade_distance 0.5
            fade_power 1001
        scale < 1.5/2.2, 1.5*2/2.2, .3/2.2 >
        translate < -1.6, 1.1, .4 >
        photons {
            target
            reflection on
            refraction on
I am still experimenting to get what I want.
is the dithering because of:
- the viewer which is doing the dithering on my 32-bit display?
- the monitor, which is a low-end monitor and can't display 10-bit color?
- roughness .1? (beginning to suspect lack of high resolution in this area or
specificity of resolution for roughness should that be necessary - really it
should be derived from the image size). maybe I just need to think about this
more and drop roughness in favor of something that keeps the gold nice and
shiny. maybe roughness is just doing exactly what it's designed to do...)
is the posterization because of:
- the colored lights I am using (Like the gels I learned about in theater stage
lighting in high school), and this is a shadow (I think so)? maybe I should
soften the shadows! I was looking at area lights, but I don't understand the
direction of the vectors, the manual shows 2 of them them going in 2 directions
at once. there are vectors that do that sort of thing, but how would you write
that with the syntax given? this is not explained very well.
- the Bits_Per_Color=16 and Output_File_Type=N (but not sure if PNG can handle
more than 8bpc)? but the posterizing should not look like 2bpc like it does now
on the shadows. still suspect the previous item.
also, the manual section on bits per color does not explain the necessary detail
that there are some bit resolutions it doesn't support (OK, what DOES it
support? what are the boundaries?), and that it means bits per primary color, so
that if you choose 16, the total number of bits is RGB 3colors*16bitsPerColor=48
bits total.
 is there a workaround for having
what I really wanted was a special effect I was able to get from POV-RAY once a
long time ago where a certain configuration caused (oh what's that effect called
where you get the rainbow-diamonds lens effect that looks so cool in some
photos? I think it's diffraction grating (in cameras, a diffraction filter) that
does that. too bad I can't seem to find a keyword for that.
I don't like the way the colors look like brightness was cranked up too high. I
think I fixed this before using roughness 0.5. I could turn down the lights, but
the surrounding sphere (not listed here) would seem darker, maybe I need to
bring up the light levels in that area or something.
the shadows look terrible in that they are posterized. blech. where did the
color bits go?
this is a work in progress. haven't got the font positionings down correctly.
I took the roughness away and now it's really posterized.
what causes this posterization and dithering? I *really* want to get rid of it.
why is it at 4K resolution that roughness is visible? is it supposed to be
visible? I read in the manual I think that increasing roughness is supposed to
be useful for shiny metals to help make them look shinier (I could not see this
logic, some explanation needed).
can I fix that somehow?
apparently you can't follow the shadowless keyword with rgb. ouch.
I noticed in 3.7 the #declare AmbientLight seems to have no effect.
Subject: Re: 16bits per color. why is my gold dithered & posterized at 4K resolution?
Date: 4 Jan 2015 14:30:59
Message: <54a994f3$1@news.povray.org>
Am 04.01.2015 um 09:39 schrieb jmichae3:
Use the "srgb" keyword whenever you pick some colour from a different
application (unless you know exactly what you're doing).
Maybe.
Maybe.
Nope. Roughness doesn't introduce noise.
I don't see your image, so it's difficult to diagnose. It might also be
due to the presence of noise in whatever the golden object reflects.
Maybe.
> maybe I should
Normally you'll be fine with just choosing two vectors of equal length,
each along one coordinate axis (e.g. "32*x, 32*y") and specifying the
"circular orient" keywords.
Nope. PNG is fine with Bits_Per_Colour=16, and should indeed not cause
any colour banding.
The limits depend on the file format chosen.
> bits total.
This is implicit in the parameter's name: It's not Bits_Per_Pixel, but
Bits_Per_Colour (meaning red, green and blue respectively).
Also, the colour banding might be due to the lack of something for the
golden object to reflect. If you're too lazy to build a full-fledged
scene around it, try a light probe.
Look for dispersion.
Might be due to using "rgb" instead of "srgb" to specify the colour.
Other way round: Reduce roughness to make stuff look more shiny.
Actually your current value of 0.5 is close to pathologic, and may
contribute to the banding effect.
Date: 4 Jan 2015 16:45:46
Message: <54a9b48a$1@news.povray.org>
>          texture {
>              pigment {
Try using "srgb" instead of "rgb".
>              finish {
>                  phong 0.9
>                  phong_size 60
>                  //roughness 0.02
>                  specular .75
>                  roughness .1
HIGH value. Make the surface look dull. Reduce to make the surface looks
more shiny.
>                  //roughness .001
>                  ambient 0.5
WAY to high for a metallic finish, especialy when there is something
around to reflect. In my opinion, should be kept under 0.1, zero been
optimum.
>                  diffuse 0.1 //.1
>                  //ambient 0.2
>                  //diffuse .3 //.1
>                  ////reflection {.3}
>                  reflection {
> color picker
Here also, use "srgb".
I suspect that setting reflection to a colour like that was originaly a
hack from way back before the metallic keyword was introduced. This may
date from the late version 1.x or early version 2.x...
>                      fresnel on
This need an interior block that define an ior to be effective.
>                      metallic 1.0
Uncomment and set BRILLIANCE to something between 2 and 9.
End of the reflection block, nullified by:
>                  reflection 1
Why a second reflection? It replace your carefully constructed
reflection block.
>                  conserve_energy
>                  //metallic  1.0
>                  specular 0.9
Also, why a second specualr statement? This one replace the previous one.
>          interior {
>              ior 2.4
>              fade_distance 0.5
>              fade_power 1001
>          photons {
>              target
>              reflection on
>              refraction on
10 bit per colour mean 30 bits per pixel, where each channels can take
1024 different values. Not what I define as "low end"...
Roughness need a LOW value to make the surface shiny and HIGH value for
dull surfaces. 0.1 is a high value.
Maybe your area_light don't use enough sublights.
For the area_light, try using larger values for the number of sublights,
like 17 by 17 and use adaptive 0 (for testing) and, if needed, adaptive
1 or 2. Using 33 by 33, or even 65 by 65 array with adaptive don't realy
slow down your render speed. I've even used up to 1025 by 1025 without
much of a performance hit.
Good values when using adaptive are: 9, 17, 33, 65, 129,...
Less that 9 tend to cause banding, or noise when using jitter.
Also, use 2 equal and perpendicular vectors with circular orient. This
makes your area_light act as if it was a spherical light.
PNG can take 5 to 16 bits per channel for red, green, blue, and
optionaly the alpha channel.
> bits total.
Yes. Total 64 bit per pixel when using the alpha channel.
Use the dispertion keyword. dispertion_samples controll the finess of
the dispertion. It default to 7.
roughness 0.5 is *very* high and result in an extremely dull finish.
> color bits go?
Not enough area_light samples?
Also, for metals, increasing the brilliance can have some good effect.
No. shadowless is a boolean switch: The light cast shadows or it don't
cast any. Also, a shadowless light never cause any specular or phong
highlight and never emit any photons in a photons scene.
If you want coloured shadows, try adding "projected_through" and an
object to a light_source. Have the normal light, then, add the
projected_through light in the exact same location. If the base light is
an area_light, the projected_through one must also be an area_light with
the exact same parameters.
The object used should be a copy of the object casting the shadows.
This declare a /user/ variable. It never had any effect unless the scene
is constructed to use that user variable.
Also, when using radiosity, the ambient part of the finishes is switched
OFF. Use emission for the finishes that are intended to actualy glow and
cast light on their surrounding.
