POV-Ray : Newsgroups : povray.general : f_helix documentation is wrong Server Time
31 Oct 2024 21:25:00 EDT (-0400)
  f_helix documentation is wrong (Message 1 to 7 of 7)
Subject: f_helix documentation is wrong
Date: 9 Dec 2014 19:00:00
Message: <web.54878c55f593dd11538d4890@news.povray.org>
f_helix1(x,y,z,n,p,r,R,s,c,a)
supposedly, the fifth parameter is the period, or "Number of turns per unit
length".
The way I read this is that, for every unit the helix object rises, it should
make one complete turn.  This is obviously not the case.
isosurface {
    function { f_helix1(x, y, z, 1, 1, 0.25, 0.75, 1.5, 1.0, 0.0) }
    max_gradient 4
    threshold 0
    contained_by { box { <-1, 0, -1> <1, 10, 1> } }
this should make 10 complete turns, and it only makes about one and a half.
A.D.B.
Subject: Re: f_helix documentation is wrong
Date: 11 Dec 2014 03:35:00
Message: <web.548956f81be1f446ea86bc440@news.povray.org>
> length".
Anthony, I can confirm same here.
Slightly different wording found in the Insert menu, Special shapes|Isosurfaces
by function.inc and placing the Isosurface f_helix into a scene file, so I went
looking for the source code after realizing it was essentially saying the number
of turns is based on a complete circle. Meaning if you apply that 2*pi to your
number of turns you should get what you expected. I checked this and seemed to
work.
Source code makes very little sense to me, although a coding math wizard
probably could get the 2*pi introduced into there somehow.
You can look it over yourself at (line 519):
https://github.com/POV-Ray/povray/blob/3.7-stable/source/backend/vm/fnintern.cpp
Guessing it's the r or r2 variables which would require the 2*pi to complete
whole turns for the "period" parameter.
Looking at the online documentation, almost halfway down page at:
http://www.povray.org/documentation/view/3.7.0/448/
I see it also says "related" to number of turns, suggesting again it wasn't
actually made to do a user-specified amount.
Interesting thing, if not, because I would have thought same as you did.
Date: 11 Dec 2014 05:22:23
Message: <5489705f$1@news.povray.org>
>> length".
> work.
So, it is per radian rather than per turn ?
Just because nobody complains does not mean all parachutes are perfect.
Date: 11 Dec 2014 10:01:23
Message: <5489b1c3$1@news.povray.org>
>>> length".
>> work.
Radians per unit length, I think.
Date: 11 Dec 2014 17:50:01
Message: <web.548a1da41be1f4461538d4890@news.povray.org>
> > length".
> work.
The source makes very little sense, period.  I tried tracing the path for the
command line options to find out the answer for another question, and I couldn't
figure out where anything was handled.
I found references to several apparently different functions called "trace" but
nowhere could I find definitions or forward declarations for them. (I downloaded
the zip of the master and went through it using grep)
It would make more sense -to me, at least- for command line parsing to be more
centralized, with options and their values stored in a dictionary that could be
queried by various modules, but that's just my opinion.  It may be that there
would be some undesirable overhead in that method, but it would seem to me that
maintainability would win out.
At any rate, it makes no sense for the period of a helix to be based on length
of the curve.  Could something have gotten mixed up between this and the
toroidal form?
A.D.B.
Date: 11 Dec 2014 18:25:00
Message: <web.548a23cf1be1f4461538d4890@news.povray.org>
> > > length".
> > work.
> toroidal form?
Or it could be based on the math for a helicoid:
http://mathworld.wolfram.com/Helicoid.html
since it doesn't seem to maintain its shape very well w/r/t different parameters
for min and max radius.  Wouldn't it be better to plot the shape in the
normal plane? http://mathworld.wolfram.com/Helix.html
See: osculating plane -> normal plane
Keep in mind that my math skills aren't stellar.  Some things I can keep up
with. Others, not so much.
A.D.B.
P.S. more comments in the code would help.  Not every programmer is a math
genius. My programming instructors would have docked me letter grades. (I'm not
trying to start a flame war here or point fingers.  I know this codebase was
written by a lot of different people over quite a long time, and I understand
that cleanup is an ongoing process.)
http://yarenty.blogspot.com/2014/03/pants-on-fire-9-lies-that-programmers.html
I'm guilty of a few of these.
A.D.B.
Date: 12 Dec 2014 03:39:09
Message: <548aa9ad$1@news.povray.org>
The code makes sense if you know how to build parallel and/or distributed
software. Then you also know what design patterns to look for ;-)
All communication between threads is handled via message passing, and all
computations are handled in worker threads that get created based on
messages with commands that tell the code to do so. Hence you cannot follow
a simple call chain in a parallel and/or distributed program because there
isn't one!
Imagine this like modern manufacturing where parts of products are produced
in different countries around the globe. If you only look at he
manufacturing plants, you will never figure out how a whole product is made
from beginning to end because some plants might get half-finished parts from
other plants, add a piece and then send them elsewhere for assembly. What
you need to know is the freight traffic between those plants to figure out
what product depends on which pre-produced part. The plants are the threads
and the freight traffic are the messages in POV-Ray 3.7...
Depending on where you looked (i.e. Windows version) it can be a bit
complicated to find the start. It is easier to start with the native main
function in
https://github.com/POV-Ray/povray/blob/3.7-stable/source/backend/povray.cpp
line 677. Parsing the command line starts in line 753 with the creation of
the ProcessRenderOptions object. Parsing takes place for command line
arguments in line 765 with the call to renderoptions.ParseString, with all
values stored in the POVMS object 'obj', which is then passed to
frontend.Start in 780, which sends it to the backend.
The actual parsing takes place in the class ProcessOptions, while the
specific implementation is included in the derived class
https://github.com/POV-Ray/povray/blob/3.7-stable/source/frontend/processrenderoptions.cpp
. Most important are the tables starting in line 89 for INI options and in
line 235 for the command line options. Most of the magic of command line
parsing can be seen in ProcessRenderOptions::ProcessUnknownString starting
on line 823.
In the backend the parsed object appears again in
https://github.com/POV-Ray/povray/blob/3.7-stable/source/backend/scene/scene.cpp
in line 437, where it arrives as argument of Scene::StartParser. Later is
arives again, this time in
https://github.com/POV-Ray/povray/blob/3.7-stable/source/backend/scene/view.cpp
line 668 as argument of View::StartRender. Tracing is started in line 1135
for the main image (radiosity pretace etc happened earlier).
So now you arrive in
https://github.com/POV-Ray/povray/blob/3.7-stable/source/backend/render/tracetask.cpp
line 215 with takes all the data and initializes the state of the tracing
code. Then eventually TraceTask::Run in  line 263 is called, which selects
the different tracing methods. The actual tracing takes place with the
various calls to the 'trace' object, which is of class TracePixel. Here the
function operator in line 258 of
https://github.com/POV-Ray/povray/blob/3.7-stable/source/backend/render/tracepixel.cpp
takes care of tracing by calling the method TraceRay from the parent class
Trace. So you continue looking in
https://github.com/POV-Ray/povray/blob/3.7-stable/source/backend/render/trace.cpp
line 108 where Trace::TraceRay does all the work. From here on, you are
basically in the same code as in 3.6 and before, though the names of
functions/methods have changed a bit.
     Thorsten
