POV-Ray : Newsgroups : povray.general : Plot 3d surface for math funtion Server Time
25 Feb 2026 15:12:57 EST (-0500)
  Plot 3d surface for math funtion (Message 1 to 5 of 5)
Subject: Plot 3d surface for math funtion
Date: 2 Jun 2014 00:00:01
Message: <web.538bf59667911eab4277cb5c0@news.povray.org>
I'm trying to use POV-Ray to plot some mathematical 3d functions, and I can make
a simple plot of the function, but I don't know how to make it look beautiful.
For example, I'm trying to plot this function
y=Sin(x)*Cos(z)
using this code:
isosurface {
function { sin(x)*sin(z)-y }
        accuracy 0.001
        contained_by{box{-2*pi,2*pi}} open
        max_gradient 5
        pigment {rgb .9}
  location <10,10,10>
  look_at   <0.0, 0.0,  0.0>
light_source { <50,50,50> 1 }
background { rgb <0,.25,.5> }
and I can get a result look like this
http://imgur.com/jxElYiI
but how can we make it look like this
http://www.mitchr.me/SS/mjrcalc/lispy/exPovWaveGraph-ART_p.png
Any suggestions and comments are appreciated.
Subject: Re: Plot 3d surface for math funtion
Date: 2 Jun 2014 02:10:00
Message: <web.538c149abb296cda8ae775cb0@news.povray.org>
> y=Sin(x)*Cos(z)
> using this code:
> isosurface {
>         accuracy 0.001
>         max_gradient 5
>         pigment {rgb .9}
> camera {
>   location <10,10,10>
You can use a scaled and translated gradient Pigment with a Color_map. Something
like this
isosurface {
        accuracy 0.001
        max_gradient 5
           gradient y
           color_map {
              [ 0 Blue ]
              [ 0.5 Green ]
              [ 1 Red ]
           scale 2.02 // a Little bit larger than the object
           translate <0,-1.01,0>
  location <10,10,10>
May be you will add additional entries to the Color_map.
Best regards,
Michael
Date: 2 Jun 2014 18:00:06
Message: <web.538cf39cbb296cda1e36f4d20@news.povray.org>
Thanks, that's very helpful.
Does Povray have predefined color functions so that we can use them instead of
manually set the color function every time? for example, commonly used color
function such as
hue, temperature map, jet, etc?
Best,
xslittlegrass
> > y=Sin(x)*Cos(z)
> > using this code:
> > isosurface {
> >         accuracy 0.001
> >         max_gradient 5
> >         pigment {rgb .9}
> > camera {
> >   location <10,10,10>
> like this
> isosurface {
>         accuracy 0.001
>         max_gradient 5
>         pigment {
>            gradient y
>            color_map {
>               [ 0 Blue ]
>               [ 0.5 Green ]
>               [ 1 Red ]
> camera {
>   location <10,10,10>
> Best regards,
> Michael
Date: 4 Jun 2014 21:59:15
Message: <538fcef3@news.povray.org>
> function such as
> Best,
> xslittlegrass
Some patterns do have default colour palletes, those are: bozo, agate,
wood, checkers (block pattern yellow and green) and hexagon (block
pattern red, green and blue). All other patterns return a gray gradient
going from black to white if you don't provide any colour_map.
The thing is that, most of the time, using a user defined map gives
beter results.
If you find yourself using the same colour map again and again in many
scenes, you can create an .INC file containing the definition of your
favourite maps. It's then a simple thing of adding:
#include "My_colour_maps.inc"
to your file and using one of your user colour_map.
An INC file is the same thing as a POV file, it's only the extention
that is different.
Date: 6 Jun 2014 10:35:01
Message: <web.5391d0c6bb296cda1e36f4d20@news.povray.org>
> > function such as
> > Best,
> > xslittlegrass
> beter results.
> that is different.
> Alain
Thanks a lot! That's very helpful.
