POV-Ray : Newsgroups : povray.general : light_souce Server Time
25 Feb 2026 15:03:15 EST (-0500)
  light_souce (Message 1 to 4 of 4)
Subject: light_souce
Date: 8 Apr 2014 21:40:00
Message: <web.5344a4343e4df9926a92a3a00@news.povray.org>
light_source {<sun_x,sun_y,sun_z>
             SpectralEmission(E_D80)
My solar irradiance in 730nm is 1.33015.I should use E_D50 or E_D65 or
E_D93.Should I choose which one is my need ?Help!
http://en.wikipedia.org/wiki/Standard_illuminant#Illuminant_series_D
Subject: Re: light_souce
Date: 9 Apr 2014 03:33:50
Message: <5344f7de$1@news.povray.org>
1.33015 @ 730 nm tells you the intensity of the light at a single
wavelength (very deep red). It tells you nothing about the overall
brightness of the light, or what the colour of that light is.
The "colour" of the light is determined by the relative intensity at all
the different wavelengths (the shape of the spectrum), the brightness by
a combination of the absolute intensity at every visible wavelength.
D50, D65 or D93 are standard distributions of wavelength intensities
meant to represent different types of daylight, they don't say anything
about "brightness".
You either need to go back to where you got the 1.33015 figure from and
get the rest of the data for other wavelengths, or just pick one of the
standard illuminants to use, D65 is quite commonly used.
By the way, the spectra for D65 etc are probably far more accurate in
the middle of the visible spectrum (around 550 nm) that right at one
edge (730 nm), so I wouldn't scale based on your value at 730 nm. If
possible get the irradiance nearer 550 nm.
Date: 10 Apr 2014 23:20:01
Message: <web.53475ed7896faf8f6a92a3a00@news.povray.org>
> about "brightness".
The 1.33015 figure is got from Solar_irradiance_Thuillier_2002,whcih measured by
instrument.It has the solar irradiance from 199nm to 2397nm.My test is single
wavelength first,then many wavelengths.My lightsource I used is a single
wavelength and the reflectivity of object is also a single wavelength . My major
is remote sensing.What I want to do is simulting  radiance .With the help of
pov,I have got luminance when I set openexr output.I have converted irradiance
to illuminance ,the illuminance in 730nm is 0.355*1.33015=0.47220325.I set
"SpectralEmission(0.47220325)".The result is luminance.Maybe I was wrong
,because the luminance pov got is  much larger than my real lumiance.I am
confusing.
Date: 11 Apr 2014 04:06:20
Message: <5347a27c$1@news.povray.org>
> confusing.
Try the example below:
#version 3.7
global_settings {assumed_gamma 1}
#default{ finish{ ambient 0.0 diffuse 1.0 }}
camera
  orthographic
  location z
  look_at  0
  right    x*image_width/image_height
light_source{ <0,0,10> color rgb 1 }
box { -1/2 1/2 pigment{ color rgb 0.5 } }
What pixel value do you get in the output image? Is it what you expect?
