POV-Ray : Newsgroups : povray.general : #write losing accuracy Server Time
12 Jul 2025 17:16:41 EDT (-0400)
  #write losing accuracy (Message 1 to 8 of 8)
Subject: #write losing accuracy
Date: 16 Mar 2014 11:35:01
Message: <web.5325c39890dbb66f3ae3bdc70@news.povray.org>
I've just used #write to write a variable with the value 11.23302 to a file, but
when I open the resulting file it contains only 11.233 .
Any ideas why that is?
Subject: Re: #write losing accuracy
Date: 16 Mar 2014 11:42:53
Message: <5325c67d@news.povray.org>
Did you define the BINARY_WORD_TYPE?
See: 3.3.2.3.4 The write Directive
Regards
I solemnly promise to kick the next angle, I see.
Date: 16 Mar 2014 12:47:54
Message: <5325d5b9@news.povray.org>
That will only write the integral part of the value as raw binary bytes.
It has nothing to do with the accuracy of the ascii representation of
floating point values.
Date: 16 Mar 2014 14:49:01
Message: <5325f21d$1@news.povray.org>
Strike that, then. :-(
Regards
Date: 16 Mar 2014 16:57:58
Message: <53261056$1@news.povray.org>
Just make sure that you actualy write up to 5 decimal places if you
want/need 5 decimal places. Take a look at the str(A,L,P) function. make
sure that P is at least 5.
Date: 18 Mar 2014 04:25:01
Message: <web.532801e33187bc37c2d977c20@news.povray.org>
> but when I open the resulting file it contains only 11.233 .
By default, POV-Ray writes only 6 significant figures (if that's the correct
phrase), at least in 32-bit POV-Ray.
Example:
#declare R = seed(52);
#fopen XYZ "test_file.txt" write
#write(XYZ,rand(R))
#fclose XYZ
..... this writes 0.943483
But this...
#write(XYZ,500 + rand(R))
..... writes 500.943 -- still 6 figures, with the final digit rounded off.
As Alain says, the way to get more decimal places is to use str()-- or vstr() if
you're writing vectors:
Like this:
#write(XYZ,str(500 + rand(R),0,12)
..... which writes 500.943482920049 -- 12 actual decimal places.
Or, for a vector,
#write(XYZ,"<",vstr(3,<rand(R),rand(R),rand(R)>,",",0,8),">") // 8 decimals
..... with the result being  <0.94348292,0.53555440,0.92402154>
As far as I know, #read reads back exactly what was written-- no more, no less.
Date: 18 Mar 2014 04:40:01
Message: <web.532805a03187bc37c2d977c20@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> Like this:
DAMN, I left off the final parenthesis there (even after double-checking my
syntax!!) Sorry! (It will cause POV-Ray to hard-crash... mea culpa...)
It should be...
#write(XYZ,str(500 + rand(R),0,12))
Date: 18 Mar 2014 05:10:01
Message: <web.53280c883187bc37c2d977c20@news.povray.org>
> > Like this:
Hmm, it actually doesn't crash, it just causes a fatal error.
(This *does* cause a crash:   #write(XYZ,500 + rand(R) // no final parenthesis
