POV-Ray : Newsgroups : povray.general : some problems about finish Server Time
28 Sep 2024 15:12:47 EDT (-0400)
  some problems about finish (Message 1 to 4 of 4)
Subject: some problems about finish
Date: 27 Feb 2014 03:25:01
Message: <web.530ef5e92d562d916a92a3a00@news.povray.org>
I want to ask how should I set the value of ambient and diffuse ?
"pigment {color rgb spectral}" I only used the reflection of object . I do not
need to consider the ambient and diffuse ,but I want to ask whether  need I to
set the parameters of ambient and diffuse ?If need, "#default{ finish{ ambient
0.1 diffuse 0.9 }}"is OK?
Subject: Re: some problems about finish
Date: 27 Feb 2014 05:05:00
Message: <web.530f0d0a99a70e2cd19b0ec40@news.povray.org>
It's up to you. Does your scene look fine to you?
Date: 27 Feb 2014 06:30:00
Message: <web.530f209899a70e2c6a92a3a00@news.povray.org>
The image of output is what I needed. Then I use the histogram to statistic the
image which output by pov. However, the profile of image is shaking so intensive
between some range. What reseasons may cause this phenomenon ?
Date: 27 Feb 2014 06:56:21
Message: <530f27e5$1@news.povray.org>
It would help if you posted your scene source and the output image
that shows the problems you describe.
