POV-Ray : Newsgroups : povray.general : Macro, Max. Number of Parameters Server Time
30 Sep 2024 00:09:50 EDT (-0400)
  Macro, Max. Number of Parameters (Message 1 to 5 of 5)
Subject: Macro, Max. Number of Parameters
Date: 25 Aug 2013 03:50:02
Message: <web.5219b694efbe9d593ba0aaa90@news.povray.org>
Hello all,
it seems that a #macro() can only handle 55 parameters. Any chance to increase
this number? I would need some more for a human model.
Thanks!
Subject: Re: Macro, Max. Number of Parameters
Date: 25 Aug 2013 04:32:33
Message: <5219c121$1@news.povray.org>
Le 25/08/2013 09:47, Sereib nous fit lire :
> Hello all,
If you need so much, it might be time to put some of them inside an array.
Date: 25 Aug 2013 07:50:19
Message: <5219ef7b$1@news.povray.org>
Am 25.08.2013 09:47, schrieb Sereib:
> Hello all,
If you're using the model only for yourself, you could modify the source
code and build a customized version of POV-Ray; the maximum number of
parameters per macro (and also per function) is controlled by
MAX_PARAMETER_LIST in source/backend/parser/parse.h.
Date: 25 Aug 2013 17:04:34
Message: <521a7162$1@news.povray.org>
> Hello all,
> Thanks!
You can do as is done for blobman and make human: Use vectors to specify
a bunch of related angles, like those of the joins of the fingers or
shoulder and arm. That way, a single parameter can cary up to 5 values.
You can pass an array or a spline as a parameter.
Date: 26 Aug 2013 07:45:01
Message: <web.521b3f233306ef28b8c295cc0@news.povray.org>
> > Hello all,
> > Thanks!
Good idea(s), thank you all!
