Is it possible to access an object attributes (position).
e.g.
I have declared an object that is an intersection of several objects and
translated it to a location. This object is held in an array.
Can I then access the x, y, z location of that object somehow?
Thanks
Seanb
On Wed, 15 May 2013 19:19:54 +0200, s.day <s.d### [at] uel ac uk> wrote:
> Hi,
> e.g.
> Thanks
> Seanb
ObjectCenter = min_extent(Object)+.5*(max_extent(Object)-minExtent(Object))
-Nekar Xenos-
> > Hi,
> > e.g.
> > Thanks
> > Seanb
> -Nekar Xenos-
Thanks, just what I needed.
Sean
You're welcome :)
-Nekar Xenos-
Or 0.5*(min + max) if you're a fan of distributive law ;)
Also note that min/max_extend is actually the bounding
box and may not yield the expected position for all objects.
On Wed, 15 May 2013 23:46:07 +0200, Christian Froeschlin <chr### [at] chrfr de>
wrote:
> Nekar Xenos wrote:
>> ObjectCenter =
It seems it's too long since I've done proper algebra. Your solution makes
perfect sense, yet can't seem to get from my solution to yours
algebraically.
-Nekar Xenos-
> makes perfect sense, yet can't seem to get from my solution to yours
> algebraically.
an algebraic mystification that is easily resolved ;)
1.0 * min + 0.5 * (max - min)
= 1.0 * min + 0.5 * max - 0.5 * min
= 0.5 * min + 0.5 * max
= 0.5 * (min + max)
> = 0.5 * (min + max)
You are right of course.
But why put that "1.0 + " on the first line?
I think of it (the first line), from my mid 20th Cent schooling, as:
Half of the difference between max and min plus the "offset" of min.
Regards
On Thu, 16 May 2013 22:55:38 +0200, Christian Froeschlin <chr### [at] chrfr de>
>> algebraically.
> = 0.5 * (min + max)
Of course. It helps to write it down and not just try and solve it in my
mind ;)
-Nekar Xenos-
>> = 0.5 * (min + max)
It did help to clarify the issue though.
-Nekar Xenos-
