POV-Ray : Newsgroups : povray.general : access object attributes Server Time
19 Nov 2025 17:37:55 EST (-0500)
  access object attributes (Message 1 to 10 of 15)
Subject: access object attributes
Date: 15 May 2013 13:20:01
Message: <web.5193c3ba1e039d0c3449e5060@news.povray.org>
Is it possible to access an object attributes (position).
e.g.
I have declared an object that is an intersection of several objects and
translated it to a location. This object is held in an array.
Can I then access the x, y, z location of that object somehow?
Thanks
Seanb
Subject: Re: access object attributes
Date: 15 May 2013 13:38:42
Message: <op.ww4zasp7ufxv4h@xena>
On Wed, 15 May 2013 19:19:54 +0200, s.day <s.d### [at] uelacuk> wrote:
> Hi,
> e.g.
> Thanks
> Seanb
ObjectCenter = min_extent(Object)+.5*(max_extent(Object)-minExtent(Object))
-Nekar Xenos-
Date: 15 May 2013 14:55:01
Message: <web.5193d9d98cb402123449e5060@news.povray.org>
> > Hi,
> > e.g.
> > Thanks
> > Seanb
> -Nekar Xenos-
Thanks, just what I needed.
Sean
Date: 15 May 2013 15:15:58
Message: <op.ww43svktufxv4h@xena>
You're welcome :)
-Nekar Xenos-
Date: 15 May 2013 17:45:40
Message: <51940204$1@news.povray.org>
Or 0.5*(min + max) if you're a fan of distributive law ;)
Also note that min/max_extend is actually the bounding
box and may not yield the expected position for all objects.
Date: 15 May 2013 23:42:25
Message: <op.ww5q8yd1ufxv4h@xena>
On Wed, 15 May 2013 23:46:07 +0200, Christian Froeschlin <chr### [at] chrfrde>
wrote:
> Nekar Xenos wrote:
>> ObjectCenter =
It seems it's too long since I've done proper algebra. Your solution makes
perfect sense, yet can't seem to get from my solution to yours
algebraically.
-Nekar Xenos-
Date: 16 May 2013 16:55:08
Message: <519547ac$1@news.povray.org>
> makes perfect sense, yet can't seem to get from my solution to yours
> algebraically.
an algebraic mystification that is easily resolved ;)
   1.0 * min + 0.5 * (max - min)
= 1.0 * min + 0.5 * max - 0.5 * min
= 0.5 * min + 0.5 * max
= 0.5 * (min + max)
Date: 16 May 2013 17:17:42
Message: <51954cf6$1@news.povray.org>
> = 0.5 * (min + max)
You are right of course.
But why put that "1.0 + " on the first line?
I think of it (the first line), from my mid 20th Cent schooling, as:
Half of the difference between max and min plus the "offset" of min.
Regards
Date: 16 May 2013 23:23:28
Message: <op.ww7k1codufxv4h@xena>
On Thu, 16 May 2013 22:55:38 +0200, Christian Froeschlin <chr### [at] chrfrde>
>> algebraically.
> = 0.5 * (min + max)
Of course. It helps to write it down and not just try and solve it in my
mind ;)
-Nekar Xenos-
Date: 16 May 2013 23:24:15
Message: <op.ww7k2oraufxv4h@xena>
>> = 0.5 * (min + max)
It did help to clarify the issue though.
-Nekar Xenos-
