I've got a spherical screen (http://sos.noaa.gov) that I want to project some
POV-RAY objects on. The way the system works is it takes a single file and
projects it onto the sphere, so if you take a Mercator projection of the earth
and project it, the sphere looks like a globe. So what I want to do is find a
way of making a single image of the object that is like a Mercator projection of
the object sitting inside the sphere, with the goal of being able to walk around
the sphere and seeing the object from the correct angle. Any ideas?
I envy you. I need one of those as decoration ;)
> file and projects it onto the sphere, so if you take a Mercator
> projection of the earth and project it, the sphere looks like a
> globe.
As far as I can see SOS uses equidistant cylindrical projection,
not Mercator. Despite the name, I think the "spherical" camera
type in POV-Ray should create this kind output with lat / lon
rectangular coordinates.
Well, I don't really have one, I have access to one at a local museum. I'll try
the "spherical" camera type. Thanks!
> > globe.
