POV-Ray : Newsgroups : povray.general : Map projection Server Time
30 Sep 2024 04:16:10 EDT (-0400)
  Map projection (Message 1 to 3 of 3)
Subject: Map projection
Date: 11 Oct 2012 14:20:00
Message: <web.50770ca235c553c5236cbab80@news.povray.org>
I've got a spherical screen (http://sos.noaa.gov) that I want to project some
POV-RAY objects on.  The way the system works is it takes a single file and
projects it onto the sphere, so if you take a Mercator projection of the earth
and project it, the sphere looks like a globe.  So what I want to do is find a
way of making a single image of the object that is like a Mercator projection of
the object sitting inside the sphere, with the goal of being able to walk around
the sphere and seeing the object from the correct angle.  Any ideas?
Subject: Re: Map projection
Date: 11 Oct 2012 15:24:17
Message: <50771ce1@news.povray.org>
I envy you. I need one of those as decoration ;)
> file and projects it onto the sphere, so if you take a Mercator
> projection of the earth and project it, the sphere looks like a
> globe.
As far as I can see SOS uses equidistant cylindrical projection,
not Mercator. Despite the name, I think the "spherical" camera
type in POV-Ray should create this kind output with lat / lon
rectangular coordinates.
Date: 11 Oct 2012 15:35:01
Message: <web.50771edf18bad867236cbab80@news.povray.org>
Well, I don't really have one, I have access to one at a local museum.  I'll try
the "spherical" camera type.    Thanks!
> > globe.
