POV-Ray : Newsgroups : povray.general : How to split image rendering across multiple computers (povray 3.7)? Server Time
19 Nov 2025 02:24:58 EST (-0500)
  How to split image rendering across multiple computers (povray 3.7)? (Message 1 to 4 of 4)
Subject: How to split image rendering across multiple computers (povray 3.7)?
Date: 23 Jul 2012 11:15:01
Message: <web.500d695410cc4e48d19b0ec40@news.povray.org>
If an image is rendered with radiosity, how would I render it across two
computers?
Subject: Re: How to split image rendering across multiple computers (povray 3.7)?
Date: 23 Jul 2012 12:48:01
Message: <500d8041$1@news.povray.org>
> two computers?
   My solution is to use a two-pass technique for radiosity: the first
pass has to be calculated on a single computer, then the final pass can
be split into pieces for each computer. As I only have two computers to
use, it's usually not much work to do it manually. The only trick is to
remember to copy the radiosity file from the first pass to the other
computers....
Jaime
Date: 23 Jul 2012 14:05:00
Message: <web.500d921c9e8de29ed19b0ec40@news.povray.org>
> > two computers?
> computers....
> Jaime
So it's the same as in 3.6?
Date: 24 Jul 2012 21:09:00
Message: <500f472c$1@news.povray.org>
>>> two computers?
>> computers....
>> Jaime
Mostly. The main difference is that you must use a command line command
to save and load the radiosity data.
