POV-Ray : Newsgroups : povray.general : CH2RGB somehow causes infinite loop Server Time
30 Sep 2024 06:18:47 EDT (-0400)
  CH2RGB somehow causes infinite loop (Message 1 to 4 of 4)
Subject: CH2RGB somehow causes infinite loop
Date: 20 May 2012 22:30:00
Message: <web.4fb9a70082db4bf885de7b680@news.povray.org>
The following scene files fall into an infinite loop:
_____________________________________________________
#version 3.6;
camera { location <0.5, 0.5, -1.1> }
light_source { -1000 * z, rgb 1 }
#local I = 0;
#while (I <= 360)
  #debug concat (str(I,0,1), "\n")
  #local I = I + 60;
box
{ 0, 1
  pigment
  { gradient x color_map
    { #local I = 0;
      #while (I <= 360)
        #debug concat (str(I,0,2), "\n")
        [I / 360 rgb CH2RGB (I)]
        #local I = I + 60;
#version 3.7;
#for (I, 0, 360, 60)
box
{ 0, 1
  pigment
    { #for (I, 0, 360, 60)
The first loop runs from 0.0 to 360.0, as expected.  The loop inside the
color_map block runs from 0.00 to 360.00, then repeats 60.00 to 360.00 until it
halts with a Blend_Map too long error.  Here is sample output from the 3.6 run.
_______________________________________________________________
Persistence of Vision(tm) Ray Tracer Version 3.6.1 (g++ 3.4.1 @
 i686-pc-linux-gnu)
Redirecting Options
  All Streams to console..........On
  Debug Stream to console.........On
  Fatal Stream to console.........On
  Render Stream to console........On
  Statistics Stream to console....On
  Warning Stream to console.......On
Parsing Options
  Input file: temp.pov (compatible to version 3.61)
  Remove bounds........On
  Split unions.........Off
  Library paths:
    /usr/local/share/povray-3.6
    /usr/local/share/povray-3.6/ini
    /usr/local/share/povray-3.6/include
    /home/ricky/Documents/POV-Ray/include
    /home/ricky/Documents/POV-Ray/Object_collection
    /home/ricky/Documents/POV-Ray/LightsysIV
    /usr/share/fonts/truetype
Output Options
  Image resolution 320 by 240 (rows 1 to 240, columns 1 to 320).
  Output file: /home/ricky/Documents/POV-Ray/test/temp.png, 24 bpp PNG
  Graphic display......On  (gamma: 2.2)
  Mosaic preview.......Off
  CPU usage histogram..Off
  Continued trace......Off
Tracing Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Light Buffer.........On
  Vista Buffer.........On   Draw Vista Buffer....Off
  Antialiasing.........Off
  Clock value:    0.000  (Animation off)
  0:00:00 Parsing
0.0
60.0
120.0
180.0
240.0
300.0
360.0
0.00
60.00
120.00
180.00
240.00
300.00
360.00
60.00
120.00
180.00
240.00
300.00
360.00
60.00
120.00
180.00
240.00
300.00
360.00
60.00
120.00
180.00
File: temp.pov  Line: 21
File Context (5 lines):
    { #local I = 0;
      #while (I <= 360)
Parse Error: Blend_Map too long.
Total Scene Processing Times
  Parse Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Total Time:    0 hours  0 minutes  0 seconds (0 seconds)
Without the CH2RGB call, the loop completes normally.  I cannot figure out
what's going wrong.  (A similar, but more complicated scene ran fine with
CHSL2RGB.)
The scene files were run with POV-Ray 3.6.1 and 3.7RC5 respectively, under
openSUSE Linux 12.1.
Subject: Re: CH2RGB somehow causes infinite loop
Date: 21 May 2012 02:59:32
Message: <4fb9e7d4$1@news.povray.org>
> CHSL2RGB.)
CH2RGB starts like:
#macro CH2RGB (H)
   #local H = mod(H, 360);
   #local H = (H < 0 ? H+360 : H);
   #switch (H)
Guess that the H used both as a local and an argument of the macro was
not a so smart idea: it ends up modifiying the original argument.
It should have been something like
#macro CH2RGB (H_not_modified)
   #local H = mod(H_not_modified, 360);
   #switch (H)
Just my 0.02€, tax not included.
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 21 May 2012 10:20:00
Message: <web.4fba4ec4f5b698985de7b680@news.povray.org>
That would be consistent with my long-ago experience of how POV-Ray works.
Should we open a bug report for colors.inc?
Date: 23 May 2012 08:43:24
Message: <4fbcdb6c$1@news.povray.org>
submitted change #5653 to address this ... thanks for raising the issue
