![](/i/fill.gif) |
The following scene files fall into an infinite loop:
_____________________________________________________
#version 3.6;
camera { location <0.5, 0.5, -1.1> }
light_source { -1000 * z, rgb 1 }
#local I = 0;
#while (I <= 360)
#debug concat (str(I,0,1), "\n")
#local I = I + 60;
box
{ 0, 1
pigment
{ gradient x color_map
{ #local I = 0;
#while (I <= 360)
#debug concat (str(I,0,2), "\n")
[I / 360 rgb CH2RGB (I)]
#local I = I + 60;
#version 3.7;
#for (I, 0, 360, 60)
box
{ 0, 1
pigment
{ #for (I, 0, 360, 60)
The first loop runs from 0.0 to 360.0, as expected. The loop inside the
color_map block runs from 0.00 to 360.00, then repeats 60.00 to 360.00 until it
halts with a Blend_Map too long error. Here is sample output from the 3.6 run.
_______________________________________________________________
Persistence of Vision(tm) Ray Tracer Version 3.6.1 (g++ 3.4.1 @
i686-pc-linux-gnu)
Redirecting Options
All Streams to console..........On
Debug Stream to console.........On
Fatal Stream to console.........On
Render Stream to console........On
Statistics Stream to console....On
Warning Stream to console.......On
Parsing Options
Input file: temp.pov (compatible to version 3.61)
Remove bounds........On
Split unions.........Off
Library paths:
/usr/local/share/povray-3.6
/usr/local/share/povray-3.6/ini
/usr/local/share/povray-3.6/include
/home/ricky/Documents/POV-Ray/include
/home/ricky/Documents/POV-Ray/Object_collection
/home/ricky/Documents/POV-Ray/LightsysIV
/usr/share/fonts/truetype
Output Options
Image resolution 320 by 240 (rows 1 to 240, columns 1 to 320).
Output file: /home/ricky/Documents/POV-Ray/test/temp.png, 24 bpp PNG
Graphic display......On (gamma: 2.2)
Mosaic preview.......Off
CPU usage histogram..Off
Continued trace......Off
Tracing Options
Quality: 9
Bounding boxes.......On Bounding threshold: 3
Light Buffer.........On
Vista Buffer.........On Draw Vista Buffer....Off
Antialiasing.........Off
Clock value: 0.000 (Animation off)
0:00:00 Parsing
0.0
60.0
120.0
180.0
240.0
300.0
360.0
0.00
60.00
120.00
180.00
240.00
300.00
360.00
60.00
120.00
180.00
240.00
300.00
360.00
60.00
120.00
180.00
240.00
300.00
360.00
60.00
120.00
180.00
File: temp.pov Line: 21
File Context (5 lines):
{ #local I = 0;
#while (I <= 360)
Parse Error: Blend_Map too long.
Total Scene Processing Times
Parse Time: 0 hours 0 minutes 0 seconds (0 seconds)
Photon Time: 0 hours 0 minutes 0 seconds (0 seconds)
Render Time: 0 hours 0 minutes 0 seconds (0 seconds)
Total Time: 0 hours 0 minutes 0 seconds (0 seconds)
Without the CH2RGB call, the loop completes normally. I cannot figure out
what's going wrong. (A similar, but more complicated scene ran fine with
CHSL2RGB.)
The scene files were run with POV-Ray 3.6.1 and 3.7RC5 respectively, under
openSUSE Linux 12.1.
![](/i/fill.gif) |
![](/i/fill.gif) |
> CHSL2RGB.)
CH2RGB starts like:
#macro CH2RGB (H)
#local H = mod(H, 360);
#local H = (H < 0 ? H+360 : H);
#switch (H)
Guess that the H used both as a local and an argument of the macro was
not a so smart idea: it ends up modifiying the original argument.
It should have been something like
#macro CH2RGB (H_not_modified)
#local H = mod(H_not_modified, 360);
#switch (H)
Just my 0.02€, tax not included.
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
![](/i/fill.gif) |
