POV-Ray : Newsgroups : povray.general : text object: utf8 ttf font? Server Time
19 Nov 2025 02:23:31 EST (-0500)
  text object: utf8 ttf font? (Message 1 to 3 of 3)
Subject: text object: utf8 ttf font?
Date: 11 May 2012 14:55:01
Message: <web.4fad5f363fe7238e6891e8c0@news.povray.org>
I have version 3.6 runnng under Debian 64 bit. I want to be able to create text
from German. I have been informed the utf8 code for this symbol is 50079 in
decimal. I understand about the global_settings { charset utf8 } command. I use
the line of code
text { ttf "cyrvetic.ttf", concat("text before", chr(50079), "text after") ...
Apparently, the supplied fonts crystal.ttf, cyrvetic.ttf, and timrom.ttf are all
ASCII. Where can I find a utf8 True Type font to add to the
/usr/share/povray/include directory? Are there any tweaks necessary to make it
work?
Any clue would be appreciated. Thanks for your patience.
Subject: Re: text object: utf8 ttf font?
Date: 11 May 2012 17:26:04
Message: <4fad83ec$1@news.povray.org>
Le 11/05/2012 20:49, David J Bush nous fit lire :
> objects using Latin characters. In particular, I want to generate the ß symbol
> the line of code
> work?
use fontforge to check that glyph U+00DF is available in your candidat font.
U+00DF is UTF-8 0xC39F (aka 50079 in base 10)
One of the largest font (in range) is arialuni.ttf, made by Microsoft.
Date: 11 May 2012 17:40:01
Message: <web.4fad8629b69a4c2ae6891e8c0@news.povray.org>
Thanks! All I had to do was toss a copy of a suitable .tff file into the include
directory. I got my eszet symbol.
