POV-Ray : Newsgroups : povray.general : Reading from a text file Server Time
10 Oct 2025 22:00:27 EDT (-0400)
  Reading from a text file (Message 1 to 10 of 14)
Subject: Reading from a text file
Date: 5 Jan 2012 08:45:00
Message: <web.4f05a8fc1cabb177be8719c80@news.povray.org>
This should be easy, but I'm having some trouble.
I would like to read a series of vectors <x,y,z> from a text file and plot the
points as spheres.  To test things out, I made a text file with 2 vectors
separated by commas.
I get this error message.  Can anyone tell me what I am doing wrong?
#fopen MyFile "myData.txt" read
# local i = 1;
  #while (i<2)
  #read (MyFile,Vector[i]
Parse Error: Expected 'undeclared identifier', empty array found instead
Here is the POV-Ray code I used:
#declare maxArray = 2;
#declare Vector = array[maxArray];
# local i = 1;
  #while (i<2)
        #read (MyFile,Vector[i])
        #local i = i + 1;
#declare Graphic = union {
sphere {
  Vector[i],    1  texture {
    pigment { color rgb <1,0,0> }
    finish { Substance }
sphere {
    pigment { color rgb <1,1,0 > }
} // end of Graphic
Subject: Re: Reading from a text file
Date: 5 Jan 2012 09:39:46
Message: <4f05b632$1@news.povray.org>
> I would like to read a series of vectors<x,y,z>  from a text file and plot the
> # local i = 1;
>    #while (i<2)
have a look at the following if you've not done that already:
http://wiki.povray.org/content/Documentation:Reference_Section_2.3#Array_Identifiers
should be #local i = 0; ????
Date: 5 Jan 2012 09:50:01
Message: <web.4f05b8068e1c2e69be8719c80@news.povray.org>
> > # local i = 1;
> >    #while (i<2)
Thanks.  However, I had previously checked out that section of the POV
reference.  I did initially have the #local i = 0, but that did not help.
Date: 5 Jan 2012 10:18:50
Message: <4f05bf5a$1@news.povray.org>
You may also consider using:
#wile (defined(filename))
Date: 5 Jan 2012 10:45:00
Message: <web.4f05c4c58e1c2e696dd25f0b0@news.povray.org>
The #read section in the docs says that a vector identifier used in this way
should be predeclared. You've declared the array, but not initialised the
element you're trying to read into. Try:
#local i = 1;
#while (i<2)
  #local Vector[i] = <0,0,0>;
  #local i = i + 1;
Also note that arrays are zero-based in index, and your code will only attempt
to read 1 vector from the file. You should set i = 0 instead, unless I have
misread your intentions!
Bill
Date: 5 Jan 2012 10:52:22
Message: <4f05c736$1@news.povray.org>
It seems to me that arrays are unduly complicated in use here.
Personally, I would prefer the following:
#while (defined(MyFile))
   #read (MyFile,Vector)
see: 3.2.2.3.3 The #read Directive
Date: 5 Jan 2012 14:15:01
Message: <web.4f05f5b48e1c2e69be8719c80@news.povray.org>
Thank you both Thomas and Bill for your comments.
I came up with 2 versions that work.  One defines an array for the points, and
the other seems to work just as well without it.
Here are the 2 versions.
1)  No array
#fopen MyFile "Set_of_PointsXYZ.txt" read
#local i = 0;
      sphere { Vector,    0.1
      pigment{ rgb <1,0,0>}
      finish { Substance }}}
      #local i = i + 1;
2) Using an array
#declare Vector = array[100000];
#local i = 0;
    #local Vector [i]  =  <0,0,0>;
        sphere { Vector[i],    0.1
Again, thanks so much for your assistance.
Date: 5 Jan 2012 15:35:01
Message: <web.4f06090f8e1c2e69cac4259f0@news.povray.org>
It looks like for your no-array option, you don't need "i" either.
Charles
Date: 5 Jan 2012 16:26:42
Message: <4f061592@news.povray.org>
> 1)  No array
> #local i = 0;
>        texture {
>        pigment{ rgb<1,0,0>}
>        #local i = i + 1;
>    #end
> 2) Using an array
> #local i = 0;
>      #local Vector [i]  =<0,0,0>;
>            texture {
Unless you plan having each spheres painted with different textures, you
should use an union and aply the texture to the union as a whole.
Using your non-array solution, it gives this:
#declare DotedSphere=
union{
       sphere { Vector,    0.1}
  texture{pigment{rgb<1,0,0>}finish{Substance}}
Faster to parse as it uses less statements and takes less place in
memory. If you have 100000 points or more, the memory requirement can
become an isue.
It may also be faster to render.
You can #declare the union and use it in more than one place.
Date: 6 Jan 2012 02:55:16
Message: <4f06a8e4$1@news.povray.org>
In the no array version, there is no need for i. Defined takes care of
it all. What Alain says is important. It is a technique that I use for
all of my scenes with a write/read code. And you can make the union
and/or the while loop as complex as you want of course.
